First oil change...what a pain in the ass šŸ˜†
goodlettjr
Houston, TX
@roadpilot..Thats how to maximize manfacturing profits.
Let’s call it $2.00 a quart. They aren’t using Motorcraft on first fill. Multiply that by 10,000 cars. $20K. Not worth the labor on 10 warrantable engine repairs averaging 2K of labor and parts each. Manufacturing yes, but major $ loss compared to the $ gain.
That's assuming engine failures which probably won't happen. Early engines fail from defects or poor assembly. Not from a quart low oil. Bet anyway they can cut corners to save they will. I also would think most dealers would not add the quart even though I hope they would.
You must be a blast at parties and to hang out with ... šŸ™„
IFFV68
Only 8.5 Qts drained. Did that include the oil in the filter?
I believe the Oil Cooler takes 1 Quart plus the Oil Filter takes 1 Quart.
SSuperDave
Friendswood TX
Next time mine is off, I am gouing to measure andd cut a trapdoor in the shape of a "U" for filter access, then drill holes and secure it with zip ties. The ran plug is at the rear and accessible without removing the tray.
Use the synthetic oil of your choice, but I've used these filterson all my Mustangs, FL-820S...
S650 Mustang First oil change...what a pain in the ass šŸ˜† 1711287396181-r
ā‰ˆ39N
Curious, is the 820S installed on the engine now? Gen4 is a new engine, I know. On the Gen3 and in the M1, the 820S would not fit due to clearance issues; it was too wide.
SSuperDave
Friendswood TX
It fits for sure, and is bigger and heavier than the FL-500.
C.A.R.
US
Mustang
I intend to tell the dealer to remove the tray when he changes the oil. The service department tells me they are unaware of the openings behind the tires in the front wheel wells, so I'm not confident they will know the correct procedures for oil changes. Has anyone else had an oil change at a dealership? Did they remove the cover?
SSuperDave
Friendswood TX
We've done numerous oil changes on these in my service dept, and the cover has come off of all of them. The techs don't like it any more than we do!
C.A.R.
US
Mustang
That is a lot of fasteners. I can understand why the techs don't like it. I hope Ford will do a correction; possibly cut a hole in the pan with a closeable door. Thanks for your response.
SSuperDave
Friendswood TX
None of our products have a trap door, but none of them have more than a handful; of bolts either!
GrabberHawk24
Denton, Md.
2024 Grabber Blue Mustang GT
Every vehicle I have changed oil in the last few years have been a P.I.T.A.!!! It's like it's a F'N contest with the engineers...Let's find the most screwed up place to put the drain plug an the filter. Then...lets put a crossmember and a pan under them just to F with their minds!
24BlueStang
Oklahoma
2024 Mustang EcoBoost
I swear it’s how the engineers get paid. How fkd up can they make it to work on the more money they make. I deal with this daily and it just gets worse and worse!
SSuperDave
Friendswood TX
Agreed. I used to work with an old tech, and when he'd see something that was needlessly difficult, he'd say "ah b'lieve the feller that designed that musta had his wife runn off with a mechanic"
