hal26
- Joined
- Nov 6, 2025
- Threads
- 4
- Messages
- 127
- Reaction score
- 118
- Location
- Central Texas
- Vehicle(s)
- 2024 Mustang Gt
yes !Just repeating what I read on here......whoever designed this underbody panel clearly never had to do their own maintenance. Now I personally have mine done for me because my time is money, but I understand the need and frustration.
To change the oil, you have to remove what feels like half the underside of the car:
And after a few oil changes, those OEM clips and holes are going to get looser and more annoying every single time.
- A boat load of screws and plastic push clips depending on trim
- Deal with awkward panel alignment during reinstall
- Oil inevitably finding its way all over the panel and your arms
- Eventually the underbody panel working loose and coming off on the road (this already happened to me)
Honestly, I think there’s a huge opportunity here for an aftermarket solution specifically for DIY owners.
Option 1:
A full replacement underbody panel system that is:
For anyone unfamiliar, Cleco fasteners are used all the time in fabrication and race car work (we use them on Asphalt Super Late Models). With the special Cleco pliers, removal and install is insanely fast and consistent. No stripped screws. No broken clips. No fighting alignment holes after the 5th oil change.
- Stronger and more durable than the OEM plastic
- Properly meshes / fits to the secondary rear panel
- Designed for repeated removal/install cycles
- Uses Cleco style fasteners instead of screws and the Christmas tree push type pins
Option 2:
Keep the OEM-style full panel, but integrate a dedicated oil service access door.
That would let you do an oil change in minutes instead of removing the entire tray every single time.
- Retains the factory mounting points and outer hardware
- Add a reinforced access panel
- Ase Cleco-style fasteners only for the service door
Something like this for the fasteners:
https://clecofasteners.info/product...kk-0-1-4-grip-plier-operated-cleco-fasteners/
Am I crazy here, or would other S650 owners actually buy this? I would buy it just so the people changing my could experience the ease of it.
