Have you tried double tapping the gas pedal?
Starship Enterprise
Starship Enterprise
MD
2025 Mustang GT Premium
Again, I'm releived this bit of knowledge was so well received. I just Googled it and apparently any Ford A10 trans will do this.
Though I saw on Reddit some said any auto trans will do this, which I don't believe.
Ninjack: It may work in your Raptor. If yours has the 10 speed, it is very possible.
DavidSteele: I don't turn my nose up on Ecoboost. It has 15 more hp than my 06 GT did with the stock 4.6 V8. I would guess you will notice a fun gear drop as well!
Luckydog7
NY
2024 Ford Mustang Dark Hotse
I've used this often in my 2024 DH. It gets real aggressive when you are in track mode and super cool in sport. Open up your exhaust and double tap coming into a light or exiting a highway and you'll wake everyone around you. Very cool feature
tktrain
Evansville, IN
I must try this next drive. There are times when normal kickdown is too violent, and dropping a couple of gears and accelerating more gently is a better option.
I've been using paddles to do it, but this sounds like a nice extra option.
Agreed. I added a Whipple on my '25 DHP. Just "flooring it" can become handful in a hurry.
Twizzty
Central Florida
2027 Corvette Z51 and others
Just in case you guys ever get into a Chevy with the A10, it also has the same exact feature but you activate it in a completely different way. Instead of the double pump you just hold down the left paddle and it drops to the lowest available gear and goes. In practice this was easier and more consistent for me but it would now exclude the EB guys so glad Ford did it their way. (EB should also still get the paddles IMHO)
davidsteele1975
DFW, Texas, USA
S650 EcoBoost
This was also a feature of the rental Fusion 1.5 EcoBoost from about 2019...
Westphal
I discovered something else about the A10 when in Sport mode by accident. When braking aggressively, it downshifts 2-3 times, maybe more depending on how long you're braking. It actually sounds like a race car braking before a turn, which is where this would be very useful.
Yes. Its supposed to keep you in a certian RPM range. Track mode does this with amazing precision. One tap and it will down shift.
Arthonon
2018 Mustang GT
The way I originally heard it was that you had to push the pedal to the floor, then immediately lift, then push it back down. I made a video to show a friend of mine, back when the A10 was new, how it worked because they were considering getting an auto but weren't confident that they could react to quick acceleration needs, etc. It's a crude video with bad aduio, but at the beginning, if you hear me say "now," that's when I pushed the pedal to the floor, lifted, and re-applied the throttle. You can see it goes from 10th to 4th.
JimC
Howell, MI
That doesn't seem to work on my wife's Cadillac CT5, and neither does the "double tap", at least not it doesn't feel the same as the Mustang.
5LTR550
San Jose Ca
2025 Dark Horse - 2025 Model Y Performance
You know oddly enough i noticed this today on my wifes 25GT with out knowing of this thread . I Will try tomorrow on the DH lol
Tommyboy64
NY
2025 Mustange GT Premium
I never knew this!
I saw on IG this morning where this guy showed that while driving a 7G A10 GT, if you double tap the gas pedal WITHOUT touching the paddles, it drops a few gears where just depressing it once to the same point only drops one gear or no gears. NO PADDLES were touched.
So I took it out today, and just in Drive I lightly double tapped the pedal and sure enough, it dropped a few gears!
To those who knew this...I did a search here and found no talk of this.
To those who might say "big deal, push the pedal down enough and you drop gears anyway"...it's not the same. The double tap drops the gears but the RPM's are lower. It literally drops a few gears without all the pedal travel needed.
(It's like the equivalent feel of blipping the paddle shifter down 3 times but this way, you are still locked in Drive and not Paddle Mode.)
I did try a double tap on the gas pedal a little further and the gear drop was a bit more aggressive. There IS a difference between this and just pushing the pedal down.
At the risk of snarky replies, I felt I had to share this because it's an interesting feature I didn't know about until today.
For those like me who didn't know this...try it and report back. There HAS to be a few of you here who didn't know the A10 did this!
I never knew this!
Twizzty
Central Florida
I haven't driven an A10 CT5 but the CT4V, ZL1's, and even a Silverado I've driven with the A10 all did it. Maybe give it another go.
I do agree the mustang feels more aggressive when you get it right but I just attributed that to the on, off, and on the throttle again making it feel that way. YMMV
