Do any of you have an issue with your clutch pedal squeaking ?
Deleted member 64400
Guest
Ive noticed from the minute I drove my 2024 Mustang GT off the lot that every time I push down the clutch pedal to switch gears it makes a slight squeaking noise, I put WD40 everywhere I could but it's still making that noise, have any of you experienced this yet? Any idea what the fix is?
S650 Mustang Do any of you have an issue with your clutch pedal squeaking ? Ljay
Is it the pedal or the spring?
Ande
Alabama
Mine does, I think it's the spring, at least that is what it sounds like to me.
Guest
Some pressure plates can be squeaky. Sometimes they wear in, sometimes they dont. Give it a few months if nothing else works.
Thanks I appreciate it, I think it's starting to go away, I hear it less and less now.
tj@steeda
2015 Steeda Mustang
Shadowblackbeast
Dallas
2018 Shelby gt350, 2025 Dark horse
Had the exact same issue on my dark horse. It’s where the spring contacts the plastic perch. Pull the spring and perch and lithium grease around the edge where the spring and perch touch and the perch mount points while you are at it. Eliminated my squeak completely. Throw the Steeda spring in while you are at it way better clutch feel
