Starship Enterprise
- Thread starter
- #1
I never knew this!
I saw on IG this morning where this guy showed that while driving a 7G A10 GT, if you double tap the gas pedal WITHOUT touching the paddles, it drops a few gears where just depressing it once to the same point only drops one gear or no gears. NO PADDLES were touched.
So I took it out today, and just in Drive I lightly double tapped the pedal and sure enough, it dropped a few gears!
To those who knew this...I did a search here and found no talk of this.
To those who might say "big deal, push the pedal down enough and you drop gears anyway"...it's not the same. The double tap drops the gears but the RPM's are lower. It literally drops a few gears without all the pedal travel needed.
(It's like the equivalent feel of blipping the paddle shifter down 3 times but this way, you are still locked in Drive and not Paddle Mode.)
I did try a double tap on the gas pedal a little further and the gear drop was a bit more aggressive. There IS a difference between this and just pushing the pedal down.
At the risk of snarky replies, I felt I had to share this because it's an interesting feature I didn't know about until today.
For those like me who didn't know this...try it and report back. There HAS to be a few of you here who didn't know the A10 did this!
