Stangerous
Space Coast, Florida
yet more info i found on ECat, might not be as many points this time, it's getting hard to find things new that people might actually care about
1. oil pump seems to be a new part (starts with PR3Z), wonder if they fixed the issue with them shattering when hitting the rev limiter? it's only ~$100
2. short blocks are ~$3200 and long blocks are ~$6200 for the Coyote
3. new flywheel for the manual transmissions
4. for some weird reason, manual transmission PCMs are $100 cheaper than automatic transmission ones
5. looks like EcoBoosts have a new air filter (part starts with PR3Z)
6. Ford's internal systems are just as janky as the stuff they make for public use
7. Ford officially calls the resonator the "front muffler"
8. diagrams of the speaker setups
6 speaker (3 is convertible, 4 is coupe)
9 speaker (5 is convertible, 6 is coupe)
12 speaker (5 is convertible, 6 is coupe)
My 2020 w/sub in the trunk is not a great system, I hope they've improved. My 2018 sounds a lot better with just an added 850 watt amp and a 10" sub.
tdstuart
2015 Mustang GT Premium
Don't know if this was already posted but ford has changed the camshafts. They also now have seals.
S650 Mustang S650 Information from ECat (Electronic Catalog) – Part Numbers, Technical Specs, Hidden Features 1686892037196
sdsteele2
Tennessee
24 Mustang GT
@roket, do you see any parts availability to replace the center stack switches between the auto start/stop and the one with a blank spot in the first position?
All of the latest press GTs have had a blank spot that’s going to bug me.
S650 Mustang S650 Information from ECat (Electronic Catalog) – Part Numbers, Technical Specs, Hidden Features IMG_7646
here are the 2 different parts
with start/stop button: PR3Z-18C858-AA
without start/stop button: PR3Z-18C858-BA
be warned, it's a $380 part
Jrws1014
North Carolina
I think he was thinking aftermarket which will allow for individual switches to move instead of the entire assembly when you press a button. If he didn’t mean that, I do. Someone needs to develop something a little more classy
yeah, i dont know why they did that. the new Transits and Escapes have a panel just like it and it works the same way, but it sometimes really iffy. i have had times where the buttons wouldn't respond unless i poked it with a pen
Jrws1014
North Carolina
Great lol. Not sure why the title switches were axed. They just scream American Muscle
couldn't tell you, but i will not miss the drive mode being on a one-way switch, there have been too many times where i overshoot the drive mode and have to circle around multiple times. i'll like having the favorite button, and i wonder how Ford got away with that hazard button? AFAIK, it is federally required to be a physical button. replacing them is a nightmare, too, as it requires buying a new FCIM, which is a part anywhere from $600-$1000, and is a bunch of stuff (volume and tuning knob, heated/cooled seat buttons, push-up switches, start/stop button), so at least this button panel is a step forward in one aspect
Interstellar
Dallas
C6 Z06
I’ve got a non-PP GT on order. Preferably would like the DH spoiler, but would take a black PP spoiler too. Are either available on the catalog?
RJV15
Los Angeles
2022 Honda Civic Si
I would think twice about a darkhorse wing on a non-pp GT.
Thats just me tho, I dont like the idea of bringing body panels over from higher trimmed models.
93-Oct Mayne
VA
It's only a matter of time before people are driving ecoboosts with aftermarket DH front fascias anyway
yep, but it's a pretty penny.
For the DH HP, PR3Z-6344210-EB is the base wing for $2874.15, and PR3Z-6344210-AB is the gurney flap for $1126.97.
For the GTPP, PR3Z-6344210-CA is the wing for $2370.97, not including the cost to paint it.
VenomousDeath
South Florida
Thanks for the info!
Can you see if the headers are different.
In a video of the new engine it looked like this on both sides(could be just on the show car), meaning it should be easier to change/remove cats? But if there is no way to tune it then it does not matter :D
Also can you see if any of the chassi/suspension components are different
I’ve always used MIL Eliminators with a cat delete no Tune required they basically move the internal sensor outside the pipe couple hundred dollars I had them on my 2011, 2017
the resonator is different for the Dark Horse
Any indication what the differences are? Larger diameter pipes? True Resonated X?
