Front inner wheel well issues
REV745DH24
Kydex and rivets. Kydex does take very well to heat for form manipulation. I do not think this is a permanent fix, it'll certainly do for a while, but I will be replacing the entire well liner once we actually figure out wtf ford was thinking.
Kydex
https://www.amazon.com/gp/product/B09V24QVFD/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Rivets
https://www.amazon.com/gp/product/B083JY27BF/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Rivet gun
https://www.amazon.com/gp/product/B083S9LMLH/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
So Kydex is something you put on and turns into plastic after the heating?
DannyJ7
United States
" It is an acrylic-polyvinyl chloride composite engineered for thermoforming fabrication, and combines properties of both the acrylic and the polyvinyl chloride components. From acrylic, it obtains rigidity and formability; from PVC, toughness, chemical resistance and good interior finish ratings. Sheet thickness ranges from .029 to .500 inches (0.74 to 12.70 mm) and can be thermoformed, post formed, brake formed and laminated.[2] "
Best way to describe it is a rigid plastic that, under heat, becomes mailable and can be fit to shape. Once it cools, it retains said shape.
It's commonly used for holsters.
ListedGuru
Mercury
It may still be aero - as in allowing wheel arch pressure to bleed out through the hole. Lets see what Job 2 brings!
So I noticed @coltgus took delivery of his GT on 12/30/23 with a build date of 12/8/23. This was on the stop/start thread and I asked him to take a look at the video @TUnica posted here because his 12/8/23 build date should be a job 2.
Here is his reply:
"They changed the hole, mine doesn't look anything like the hole in the linked video. It is smaller and offset"
Someone has since asked him to post a picture so it sounds hopeful that Ford did make some sort of change.
REV745DH24
Here is his reply:
Interesting, I wanna see the Job 2 pictures when it comes out!!
My car just arrived at the dealer. I did a quick look at the inner front fender and it looked the same as job one. Car was built 12/14. I have my kydex .080 ready to go. I will be using plastic pushpins with larger kydex washers behind for attachment. I don't believe the whole inner liner will need to be removed.
S650 Mustang Front inner wheel well issues 20240112_100314
REV745DH24
REV745DH24
Once you get it fixed, take a snapshot along with your instructions how it is done would be appreciated!
ListedGuru
Mercury
Well that is disappointing. @coltgus said his 12/8/23 build's hole looks different and is smaller. I was hoping this was changed with Job 2 but your saying otherwise. Wonder what the heck is going on here?
angermgmt14
Massachusetts
2016 GT Premium--Oxford White--A6
I'm going to repost the video I did for those people who have not had the opportunity to remove the inner fender to see some of what s occurring.
If you have already seen it ignore this.
Wonder if the 18-23 liners would work/retrofit??
DukeCLR
Vermont
I have both my S550 and S650 in the garage at the moment, is it difficult to remove the liners? I could try them.
TUnica
TUnica
South Hero VT 05486
It’s not hard, you need to remove the wheel, use a thin body panel trim tool and a 7mm socket.
Dxm
San Antonio
S650 Mustang Front inner wheel well issues IMG_6117
This is what my mechanic came up with. Used a door mat to make the patch. All that was needed to prep the material was to remove the fuzzy surface from it. It is flexible, it is as thick as the liner, and these door mats last forever.
Also, instead of taking off the liner, my mechanic used blind rivets -- they need a special gun. Basically these blind rivets expand from behind, very easy to install.
S650 Mustang Front inner wheel well issues 1705193767919
S650 Mustang Front inner wheel well issues IMG_6118
S650 Mustang Front inner wheel well issues Screenshot 2024-01-13 at 7.49.00 PM
