Engine Noise
Like the old PVCs that were in the valve covers they just pull out. That a laborate design there's no way it will twist out it has to pull out. Remember PVC have suction.
Doug Watson
Doug Watson
So Ford put a collar around the PCV valve it should twist counterclockwise to remove but still no luck. I'll go to the dealer and see what method they use to remove it.
Doug Watson
Doug Watson
Ford dealer has no procedures from Ford on how to remove the PCV Valve. They put a collar on to prevent people from removing it. If you have an issue with the PCV valve then Ford has to replace the valve cover assembly, that's crazy.
Big Bird
2017 Chevrolet Bolt EV, 2024 Mustang GT
I've been attempting to locate the "fix" for removing the PCV Valve with the molded plastic collar around it for months after scratching mine up a bit during a catch can install. Could only find a couple of random forum/Reddit posts from F150 owners who were running into the same issue, but they all went silent with no resolution.
While I'm glad that I finally have an answer, it's a huge bummer that you can no longer just twist these out for a quick, DIY swap. Overengineering to force a trip to your local service department at it's finest.
The part designer must be a relative of the unserviceable carbon filters.
Would you mine posting a couple pics when you get a chance?
Big Bird
I tend to have issues with my photos posting successfully on 7G, but I'll certainly give it another shot. Here's a close-up view of this molded plastic collar around the base of the PCV Valve, similar to what Doug shared previously in this thread. The 'damage' was nothing major, just some plastic-on-plastic marring.
S650 Mustang Engine Noise IMG_2038
350 Feet
CA.
2018 GT350 J0060
Repeat after me; thank you Jim Farley, and all the eco-nazies.
Doug Watson
Doug Watson
Were you able to get it out?
Big Bird
Unfortunately, I was not. After trying to outsmart that incredibly frustrating design for a few minutes, and finding no help online, I finally threw in the towel to avoid actually breaking it beyond repair (and then needing to replace the entire valve cover, apparently).
Good news is, you cannot see the scratched up PCV Valve tip underneath the quick disconnect hose that attaches to the catch can. If you believe that this knocking sound (buzzing from this area seems to be normal operation) is being caused by a bad PCV Valve, I would probably recommend taking it back to the dealership to have them remove/disassemble the valve cover under warranty. Seems like an unnecessary risk otherwise, especially with that brand new long block replacement. Best of luck.
Doug Watson
Doug Watson
The fustrating part is this is a new engine from Ford.
Ford told me that this noise I normal ....
Because it is. The OP is just hyper sensitive to noises after his engine replacement. I can't say I blame him.
