Amber DRL via forscan?
GrabThatBlue
Between Canada and Europe
So0_NaSTy
NY
2024 Ford Mustang GT Premium
No no no. I have everything saved. My as built is saved… I’m just saying, to avoid over saving and having so many files, I made one OEM save then made any changes in that module. So if there’s something I changed that I don’t know the prior OEM number for, I can revert, but It’ll revert all changes to factory, you know?
I’m not playing with fire or anything, I have my factory saves, but I’d just need to change the stuff I like, back.
GrabThatBlue
OMG, this is the reason why I told you to get the spreadsheet.
The spreadsheet is not helping you with saving. The spreadsheet gives you an idea about what you are changing in Forscan.
assuming we are talking about the center screen, there are some gauge differences, mainly the oil pressure domain being changed from 0-100psi to 0-175psi, boost gauge (if you enabled it) has a supercharger icon instead of a turbo, you get actual oil temp numbers instead of an unlabeled gauge, "transmission oil temp" has changed to "transaxle oil temp", and changes the domain to be up to 350 degrees instead of 300. there is no fixing the lincoln thing, that's just some bug or side effect of changing the vehicle. i guess Ford built the Mustang theme off of a Lincoln one and forgot to change out that image for the GTD
Probably figured anyone driving a GTD would never look at their mileage...
GrabThatBlue
I think nobody has tried this yet
FrontTurn_Position_Lamps_Cfg (FTPLC)
726-71-03x*--0 =FTPLC TURN_ONLY1 =FTPLC TURN_POSITION
I used the search option on the forum but I can't see anyone tried this one yet.
Our cars have this set to 0. We should try change it to 1.
GrabThatBlue
My As-Built already has this set to 1. Unless youre saying change the second digit out of the four as in making it 01A1
The location where the * is should be set to 1.
In this case it's the second digit.
GrabThatBlue
I gotta unscrew up my BCM from prior attempts, I'll try er' out this evening.
The last two digits on every Forscan line are checksums. You should not change those digits at any cost. Leave them alone. They change automatically when you change something in the adress.
i mean, you can change them, but FORScan will just overwrite it with the corrected checksum, unless you calculated the correct checksum on your own
Lidsoff
Pittsburgh
Darkhorse #0627
No dice.
Magic88
Bennington
I'm going to find another hobby now.
Can someone lock this thread and change the title to "No amber DRL's, don't bother asking", and pin it at the top of the main board?
Thank you to everyone for their time working through everything!
im not giving up. its now the weekend and i have nothing to do. we have to be close to something. that Prog_Legend guy proved its possible, now we just need to find out how
Lidsoff
Pittsburgh
Darkhorse #0627
I’m down for being any sort of guinea pig. I’ll be on standby. I don’t understand this enough I just know how to put numbers in.
