Amber DRL via forscan?
GrabThatBlue
Between Canada and Europe
already tried a bunch. they arent assigned to anything and end up giving SYNC a weird look with Lincoln fonts, and an F-150 in the fuel economy screen and a regular GT in the My Mustang menu. you can actually see what a bunch of those vehicles/programs are at this link: https://en.wikipedia.org/wiki/User:KA467/Ford_development_codes
I really like the F-150 startup screen lol. Damn it. No luck in nothing these couple of days.
Wish we could have this "finally" feeling after all this work.
@So0_NaSTy
You can change it to A1, then you have at least a Mustang Mach-E GT instead of your Lincoln LOL
So0_NaSTy
NY
2024 Ford Mustang GT Premium
@So0_NaSTy
LMAOO. What did those 2 lines change? Was one the My Mustang menu and ones the startup?
GrabThatBlue
Not so sure, but since Roket changed the line that had 2D for the GTD, we know that one changed the center screen. I have no clue what the 2E GTD value does, or maybe it didn't do anything except for enabling some special GTD features for the IPC module.
So0_NaSTy
NY
Tbfh, I don’t notice anything really changed besides I did see that in reverse, it shows a GTD, my Mustang, and on startup / exit. Besides that, didn’t notice gauge differences.
@So0_NaSTy
yeah, it sucks we havent found anything about the DRLs yet, but think of the other things we found out along the way
2E and 2D are exactly the same, except one has the B&O text and the other does on the splash screen
So0_NaSTy
NY
Yeah. Whatever you said to put, does say B&O, which is correct for my car. But somewhere along those lines it’s transpiring a Lincoln. Gotta experiment the why.
GrabThatBlue
I'm sorry, that was a typo, I meant 3E on the this line:
7D0-03-02**xxxxxxxx--
GrabThatBlue
Have you changed it back to your normal GT setting to see if that Lincoln is still there?
So0_NaSTy
NY
Haven’t reverted. Would need to change back everything in that module smh. But I’d assume it would go back to as it should.
GrabThatBlue
To find out if this Lincoln thing is really from the change you made, is to change it back to your previous setting. If the Lincoln is still there, than you made some error. If not, than it's just a side effect from the code.
So only change the line back that you changed to GTD to check. You don't have to change everything back in that module.
assuming we are talking about the center screen, there are some gauge differences, mainly the oil pressure domain being changed from 0-100psi to 0-175psi, boost gauge (if you enabled it) has a supercharger icon instead of a turbo, you get actual oil temp numbers instead of an unlabeled gauge, "transmission oil temp" has changed to "transaxle oil temp", and changes the domain to be up to 350 degrees instead of 300. there is no fixing the lincoln thing, that's just some bug or side effect of changing the vehicle. i guess Ford built the Mustang theme off of a Lincoln one and forgot to change out that image for the GTD
So0_NaSTy
NY
Interesting. I’m gonna need to check this. When I go to aux gauges, and go to edit, I do see it says “vacuum/boost”. Besides that, looks the same. May need to look harder because I didn’t really concentrate.
So0_NaSTy
NY
No im saying the only save I have for that module was prior to the GTD adjustments. So to revert, I’d need to revert all you know? I don’t save per change. Which I think I’m gonna start from now on.
GrabThatBlue
I'm sorry, I don't get it.
You don't need any save data to revert back. The only thing you need to do is to change the values manually back from GTD to your GT setting.
7D0-03-01xxxx2Dxxxxxx
7D0-03-023Exxxxxxxxxx
2D to 1C (if you have B&O) or 1D if you don't have B&O.
3E to 23
That's it.
So0_NaSTy
NY
3E to 23
That's it.
Ohhhhh. I didn’t know if we knew the actual variables. Okay. I will change back probably tomorrow to guarantee.
