Amber DRL via forscan?
So0_NaSTy
NY
2024 Ford Mustang GT Premium
Guys, I compared the GTD with my GT and I got the GTD splash screen to work, as you maybe saw in another topic that I opened.
Then I was confident that with this information I can find the difference in the LDCMA, HCM and BCM, so I compared line by line manually and wrote everything down that had to do with DRL and turn signals and also some other fun stuff like the splash screen etc.
GTDifferenceGTD
7D0-03-01xxxx2Dxxxx--43411C0D0991GT Premium B&O vs GTD Splash screen55532D0D09C6
7D0-03-02**xxxxxxxx--23000906000EVehicle type S650 vs GTD3E0009060029
7D0-09-01xxxxx*xxxx--6B17492CAF879 vs B = Daytime Running Lamps Control Function (DRLCF) Off vs On43172B2CA83A
720-01-01xx*xxxxxxx--8F482C64D2624 vs 0 = max speed On vs Off8C080C64C2EF
720-11-01xxx*xxxxxx--C8352400207A5 vs 6 = Virtual Speedometer StyleC8260400204B
726-21-01x*xxxxxxxx--020202020259DRLBYAUTOLAMPS inoperative vs Enabled010101010154
726-27-02xxx*xxxxxx--01020001015BDRLBYAUTOLAMPS inoperative vs Enabled01010001015A
726-38-01xxxxxxx*xx--01640A0001D61 vs 0 = DRL_IncludeParklamps_Cfg (DRLIPC) Enabled vs Disabled01640A0000D5
726-40-02xxx*xxxxxx--0001010100721 vs 0 = Front_LED_Turn_Outage_Cfg (FLEDTOC) Outage vs No Outage000001010071
I changed all the differences to the GTD version, with no luck. I also rebooted the modules after making the change, because sometimes you need to do the reboot to get everything to work.
I have a feeling I'm almost there, but because I had to check every line manually, I might have missed something.
Luckily @roket said he is going to do the same thing as me, but with ChatGPT and hopefully he will find the missing link.
We narrowed this thing down to the max. There should be just a slight change to do and we will get it.
I kept all the settings that I made like that, so if anybody found the missing link, I only have to add that setting to the ones I already programmed and get it to work.
What my car does right now when I close it, is that the DRL's are shining pink and very bright. I really love that color and it only shows the pink light after closing the door before locking the car.
I'm not giving up, but I'm going to bed now.
For the splash screen to do GTD, did you change line 7DO-03-02?
allenouo
Australia
S650 Mustang GT
Also, I did notice that when the white DRL is on, and the turn signal is activated, the white is on when there is no amber light on...if that makes sense. So when the sequential function goes through, it starts as all 3 lights amber, then 2 amber and 1 white, then 2 white and 1 amber, then all white. The sequence repeats. Can not confirm if it did this before the above changes though.
I saw that white DRL on with the turn signal on US cars in some YouTube videos. My Australian model doesn't do it and was trying to figure that out. Thanks for this result I will give it a go.
there is a little nuance to when the DRL comes on, because it only stays on when the indicator is active when its dark outside. otherwise, the DRL shuts off when the indicator is activated and fades back on when its shut off
GrabThatBlue
Between Canada and Europe
I just finished checking all differences for the second time.
HCM between GTD and GT is identical
LDCMA between GTD and GT is identical
BCM has 4 different lighting settings between GTD and GT that has to do with front LED/DRL/Turn signals. These are exactly the lines that I changed yesterday with no luck.
These are the 4 adresses that are different between the GTD and GT that I changed with no luck.
GTGTD
I'm pretty sure my car is a Job 2. Production date 29 september 2024.
What I also found out that the GTD has these adresses that my car doesn't have:
726-90-020000000000BF
726-97-010000000000C5
726-97-020000000000C6
And I also have these adresses that the GTD doesn't have:
726-235-0163CB4CDD73
726-236-0163CB47B231
726-237-0163CB41D4E3
726-238-0163CB3C739C
726-239-0100000000F0
726-240-010000000061
I need some input from somebody else. I think I can't go further without it.
FVS2
Melbourne, FL
2023 F150 Tremor 2024 Saleen Mustang 022
GTGTD
What do you need?
I’m familiar with ForScan and understand the basics behind it. So if you can tell me what addresses you need to see, I can screen shot them for you. I do t know if I have a job 1 or 2, will have to find my window sticker to confirm.
GrabThatBlue
What do you need?
I already checked all adresses.
I need somebody who can think further with the information we have at the moment.
The guy who got it to work did it on a 2025 Mustang. Maybe that's the thing..
The 4 BCM lines should be programmed by somebody who has a 2025.
FVS2
Melbourne, FL
Gotcha.
I wish I had a GTD to mess with.
The missing and different addresses seems to be the issue. There has to be a way to add or write those addresses to the vehicle. Not sure how, but there has to be a way
I know it seems trivial just to have Amber DRLs but there has to be a way. LOL
One thing we don't know... if all GTD's actually have amber DRL's... watching the one going around the nurburgring had white DRL's, so comparing the asbuilts may reveal no clues. Sorry I'm of little help with that...
Magic88
Bennington
We've been fooled this whole time. Ford took a publicity shot, using the hazards, like people on here, bastards!!!
No idea if this is true, but it's what I'm going to tell myself when I see someone post on this topic. Hopefully I can resist the click (won't happen)
GrabThatBlue
Alright, I went back to my car to see if all values are correct and I might found the issue. And it's bad news.
I checked all lines again to see if there was any mistake and at first I thought I found the mistake.
726-21-01 is the line where the GTD has 0101 0101 01-- and my GT has 0202 0202 02--
01 means Enabled, 02 means not available
And not availabe doesn't mean it is disabled, because 00 is the value to have it disabled.
So I changed it back to 01 and you probably already guessed it. BCM changed it back to 02 again because it is not available.
All other lines where okay except for this one. This means the GTD has another BCM and I'm guessing that maybe the 2025 models or only the Job 2 from 2025 may get this to work.
FVS2
Melbourne, FL
Do you have a GTD VIN by chance?
I can search my parts catalog on Monday and see if there is a different BCM part number for it VS my GT BCM part number. There may even be different wire harnesses as well.
it would seem odd that the GTD and other trims would have a different hardware configuration but who knows.
GrabThatBlue
It's your turn to try lol, I'm done.
2FA6P9LJ2SH199958
FVS2
Melbourne, FL
2FA6P9LJ2SH199958
LMAO.
Let me see what I can find next week. If the BCMs or even the headlights are different, then this will not be easy. But if it’s a wiring or harness issue, then we can figure it out.
Ford's ECat does not know some GTD VINs yet, i tried. there are also no BCMs listed for the GTD in general. HCM is listed as NL1Z-13K198-T, GWM is listed as PU5Z-14G490-AU, LDCMA/B is listed as P3HZ-13C788-D, and headlights are listed as PR3Z-13008-X for left and PR3Z-13008-R for right. apart from the gateway module, all of those parts are also used on the regular Mustang. BCM software number is the same, its been demonstrated that it can be done per-side so the HCM software is irrelevant, which leaves the LDCMA/B software. its also been mentioned that 2024 Job 2 and later are the only ones capable of having this change done, and from my samples, the GTD, 2024 Job 2, and 2025 Job 2 have the same LDCMA/B software number. this is 100% a software change, we just need to find it
GrabThatBlue
LMAO.
100% that the headlights are different. There are tons of different headlights if you search for the part numbers, but we don't really know why. Even on the GT's and Dark Horses.
