Air Boxes Closed or Open?!?!
What puzzles me is why the onboard gauge should be wrong. In theory the car knows the distance driven from tyre rotations, time is time, doesn't change, and from what I've see OBD2 speed readings are spot on.
Does anyone know where the error comes from?
Ford quality math?...
goodlettjr
Houston, TX
Time = Time
1 tire rotation = X Feet / inches
X Tire Rotations = X distance driven
If you drive your car 5 mph for a 1/4 mile then your mustang’s track app should be accurate. If you run a hot 1/4 mile (drag race) then you will have tire slippage. The question is, how much tire slippage.
X tire rotations in slippage = X feet / inches
So (X Tire Rotations + X rotations in slippage) =x feet which is less than 1320 ft. The track app will show that you finished in a shorter time. Hope this helps.
This all assumes that you have stock tires and that all stock tires are calibrated exactly which I don’t know if they are or aren’t.
135Hoser
2024 Dorkhorse, 2024 CR-V
Why give factual numbers when that will just make owners sad.
If they give favourable numbers then owners feel better about their purchase.
It's similar psychology behind why fitness watches report vastly inflated calorie burned numbers.
Time = Time
Thank you. Completely forgot wheelspin.šŸ‘
Does dragy use a satellite that ford is unable to ping?
