Air Boxes Closed or Open?!?!
Mastermind46
Denver
thinkautotech.com
2012 Nissan Xterra, 2023 Ford F-150 Raptor
I brought my own to market since none of the other aftermarket options meet my requirements. They are all geared towards maximum flow whereas mine target oem filtration efficiency while being reusable.
I sell them directly through our website.
https://thinkautotech.com/ThInK Auto Tech
There is a thread on here that has the entire development process and testing included in it.
NightMoves
NightMoves
North Mississippi
2024 Ford Mustang GT Premium
Hey that’s super awesome! I’ll check them out!
Just letting you know they aren't accurate. The 12.5 is.
TBF, if our position is 11.4 is inaccurate then it’s almost certain the 12.5 is also inaccurate
1/4 mile tin
at a track, with a solid 60’ and good reaction time and repeatable follow up runs would be generally accepted
as to the open/ closed: I can tell you from first hand experience that no matter how much evidence, dyno runs, time slips you provide, there will be some online who insist what you did isn’t sound or the results are meaningless. IF there was no ram air, open elements should provide better breathing but, you would only note a difference in power if there was a limitation with the previous setup.
I went through this on my ‘97 and still had people crying “heat soak” even after back to back to back dyno runs on the same dyno showing no significant power loss The open filter netted me 9.9 hp At the wheel. Repeatable. Put the stocker back on& dropped 9,8.
that said, I agree the Onboard gauges and timers aren’t the best way to measure your 1/4 mile times.
NightMoves
NightMoves
North Mississippi
1/4 mile tin
Exactly. I feel that. Time to hit the track up! And some dyno tests.
that’s super good info thanks my guy!
Nace.Oh
New Jersey
2024 Mustang Gt PP, 2021 Explorer
take this with a grain of salt butttt.. What if what your experiencing is bc your not giving the car enough time to properly adjust the fuel trims therefore it's making less than ideal adjustments on the fly to compensate? You throw the lids on after only a pass or two ( 1 mile ish max?) and open them back up to what the car has stored in the fuel trims and it's happy again? I have a vague experience tuning old DSM's and that makes sense to me with my vague understanding of how it all works.
NightMoves
NightMoves
North Mississippi
Oh shit never thought of that! That’s also some good points!
I’m making notes here yall.
thanks for all the input!
Nace.Oh
New Jersey
Thanks! I was hoping to help but I'm sure alot of the stuff we did back then would not apply today. But given these cars run the Wideband o2's and shown alot of factory adjustability it would make sense.. I'd like to see 150 or so miles with lids on and see if the times improve.
NightMoves
NightMoves
North Mississippi
Oh yeah that’s a good idea too.
What puzzles me is why the onboard gauge should be wrong. In theory the car knows the distance driven from tyre rotations, time is time, doesn't change, and from what I've see OBD2 speed readings are spot on.
Does anyone know where the error comes from?
True, but the 12.5 is at least possible
Doubt it. The car adjusts almost instantly
Paul's stable
Maple Ridge BC Canada
There is something else at play here and it's not closed vs. opened air boxes. The delta between open closed is 1.1 seconds which cannot be achieved by opening the air boxes even if the air entering was the same as closed which is impossible with under hood temps. Something else is causing this delta and it is not the air boxes.
Takes way bigger changes to get to 1.1 second delta (HP Speaking).
I have the Whipple competition open air boxes. The big difference with these are that the box area is bigger so more air can get around the whole filter. When I took off the stock ones it seemed from the dirt marks that the air was only going in a small area of the filter.
Motor Trend says my Dark Horse is:
12.0 at 118.4
The Tremec option slows it down by 0.6 and 5 mph.
(Those numbers are with the Trofeo RS tires)
