6 speed.. Accidentally shifting into reverse
Racer57
Illinois
2025 Shelby GT350
2025 6 Speed Shelby
There has been times while sitting at stoplight, in neutral and then shifting into first, it accidentally goes into reverse without me pulling up on the lockout. Thankfully my dash informs me and prevents me from backing into a car behind me. Car has 1,500 miles on it.
Anyone else had this happen ?
Ninjak
Posting from the Shadows
The Shadows
No? My shifter has been rock solid. I also have a Steeda short throw installed. Never had the issue you are describing.
DarkHorsePremium
CA, Bay Area
I only used Momo shift knobs in my Subarus and never had an issue. I just did a quick AI search and they're talking about plastic shift collars and some aftermarket knobs being problematic. If you're so inclined you can probably take the console out and see where the problem is. But for a 2025 or a car that's under warranty I would just take it in and let them figure it out. Bottom line it's unsafe. If you can get your car into reverse without manipulating the lockout, that's trouble waiting to happen.
D/\rK•650
2025 Mustang DarkHorse
Yes i definitely agree this is an accident waiting to happen. Take it in to have it fixed ASAPâť—. Plus this is on an 25 Shelby , man that would really suck if it got banged up. Goodluck&Godspeed
NegativeMultiplier
Uh, that's definitely NOT supposed to happen. Immediately get that checked out.
Of all the 6 speeds I've driven, including my own, this is something I've never ever experienced. You have a defective shifter.
steedazach
Valdosta
S650
2025 6 Speed Shelby
Defiantly not supposed to happen. And it could be a couple reasons like defective lockout collar or damaged spring in the lockout collar, or maybe even a misaligned shifting collar. I would definaslyy take it back to the dealer to get it looked at while still under waranty. But, if you are looking to ever upgrade, let us know and we can help you out.
JPGC_S650
SC
2025 6 Speed Shelby
Nope, never had that happen when stock or with the MGW shifter. With the MGW, not even sure it could happen with how robust it is and since the reverse mechanics replaces the "pull up" collar, with a forceful push down motion. With the stock setup, it doesn't surprise me as with how flimsy the stock shifter is.
rush014
Carterville IL
1991 Corvette ZR-1 , 2010 Crystal Red ZR1, 2014 Altima
I would call Shelby and explain your issue...... As I'm sure the limited Shelby warranty is still in place. If they touched the transmission in any way, you should be covered for 3 years or 36,000 miles.
This is not normal as others have said, and just unsafe.
