Slight thunk when shifting 6sp into 1st
GT 4 LC
ohio
2022 Mustang GT
My '24 PP GT does this also. If the car is rolling even a little there is no thud. At a full stop it comes and goes. I've actually found a way to mitigate it by holding the clutch in for a couple seconds, and then slowly pushing the gear shift into first letting the synchros mesh slowly (this seems to lessen the frequency). If I'm in a hurry and push the clutch in and shift rapidly into first its gonna thud almost every time. I agree with the above posts I don't think it's anything to worry about. Transmission shifts smooth in all 6 gears (and reverse) and the rear end is quiet. You could have the service dept look at it, but in all likelihood they're going to say that is normal operation.
Interesting to say the least. I haven't experience this as I have the REV MATCH on and down shift so I can't remember experiencing this issue. Maybe give it a try!!!!!!
Dena
Phoenix AZ
What??? …. Yes it was a lot of work so many people learned how to shift without using the clutch by running the engine at the correct speed to avoid grinding.
That would blow the transmission not using the clutch when upshifting the gears!!!! Never done that on my shifting in Mustangs!
We rebuilt a 1950 ford pickup and the transmission didn't have synchromesh. My father passed it on to my brother and soon he was driving without a clutch. We know a truck driver and he talks about doing it as well.
I drove the pickup a little but didn't really have the time to master than transmission so I would agree, I am not going to try it on my mustang either. It probably wouldn't damage the gears but it would put excessive wear on the synchromesh clutches.
P2
My 2015 GT Premium 6 speed did this as well. It's nothing to worry about. If you don't like the "thump" then push the clutch in, wait 10 seconds and then shift into first. You won't hear/feel it then.
Just thought. Ford is very adamant about fluid level in the MT. Make sure its at the proper level. For the transmission the manual specifies a fill level that is 10mm ± 3mm below the plug opening. Waiting 5 or 10 seconds for a smooth shift into 1st tells me something is still spinng. Maybe try changing the fluid to something like Redline.
Instant Action
Instant Action
I ran Redline oil in the transmissions of both my E92 M3’s and it really made shifting slicker than snot. I would love to use it in my MT86 trans but Redline doesn’t list a compatible oil for it yet on their website, but if and when they do it’s a no brainer to switch.
JDR09
Monterey, CA
2024 Mustang GT PP
My S650 GT PP also does this. Only from a dead stop to 1st; never in any other condition.
Jdio
2024 gt pp 2018 gt350 2003 cobra
This doesn't happen all the time with my GT PP 6sp, but when I'm sitting at a light, dead stop with the clutch out and I push the clutch to the floor, I pause for a second and select 1st gear, there is a slight thunk, more felt than heard but the strange part is it doesn't feel like its coming from the transmission, more like its coming from the rear as if the car had a transaxle, which it obviously doesn't. This happens maybe 8 out of 10 times.
Anyone else felt this in their manual GT's?
i put in the steeda short throw with new bushing and it makes a difference
highvoltage
NorCal to SoCal
2024 Mustang GT 6spd
Magic88
Bennington
Paul's stable
Maple Ridge BC Canada
Gone thru all these posts and have to say I'm glad my choice to go with the Tremec in the DH. As I have no problems to mention with it. As for clutch less up shifting it's easy just takes a few grinds to get to the sweat spot.
GnatsumGT
Tennessee
2005 Corvette
I’m hoping a MGW shifter will fix this and also help with the nibble going from 1 to 2 and 2 to 3. After reading some of these posts, I will also be looking to replace the trans fluid.
