2025 GT engine oil temp runs hot
Cz_Ziemniak
Maine
S197
Doubt the inlet temps are any higher. Both IM’s are made of a plastic composite. If the oil in gen 4’s runs hotter than gen 3’s, its probably because they make more power. More pressure = more boom = more heat. I’m sure someone smarter than me can figure out the math to all of it.
I wanted PP for the cooler and larger radiator for driving in AZ. Also for the Brembos when mountain driving. One can get by without but with any spirited driving one may find things not go as planned ending in not wanted results.
Garcia172
S650
Okay…. Kinda long-ish post..
Yes, the Gen 4 (2024+) Coyote engine generally runs with higher oil and operating temperatures compared to the Gen 3 (2018–2023) Coyote, often sitting in the 210°F–230°F+ range under normal driving, with reports of higher temps in non-Performance Pack cars. This is considered normal by Ford for modern, high-compression aluminum engines. [1, 2, 3, 4]
Here is why the Gen 4 Coyote runs hotter:
• Dual Throttle Body Intake System: The Gen 4 features a new, more complex air induction system (dual throttle bodies and air boxes) designed for higher performance and emissions compliance. This system, combined with a more restrictive engine cover, can cause higher inlet air temperatures and overall engine bay heat management challenges compared to the simpler Gen 3 intake.
• Increased Compression and Power: The Gen 4 continues to push the limits of power output (up to 486 hp in the GT and 500 hp in the Dark Horse) from a 5.0L displacement, which inherently generates more heat energy.
• Revised Cylinder Heads & Oil Management: The Gen 4 features significantly different, more complex cylinder heads with updated camshaft towers and a redesigned rear cover. These design changes affect heat dissipation.
• Engine Tuning: The Gen 4 ECU (Engine Control Unit) is tuned to run at higher temperatures for improved fuel efficiency and lower emissions. [5, 6, 7, 8, 9]
While Gen 3 engines (2018–2023) also tend to run in the 200°F–210°F range, they often display slightly lower overall operating temperatures under similar driving conditions compared to the newer Gen 4, which is designed to handle higher operational heat. [4, 10]
///break ///
Short answer:
At 240 °F, a typical 5W‑30 is effectively operating squarely in 20‑weight territory — not just “close to” it. At that point, yes, it behaves much more like a 5W‑20 than a true 30‑weight.
Let’s put real numbers on it so this isn’t hand‑wavy.
1. Baseline: where a 5W‑30 starts
Under SAE J300, a 30‑weight is defined at 100 °C (212 °F):
  • SAE 30: 9.3 – 12.5 cSt @ 212 °F
  • SAE 20: 5.6 – 9.3 cSt @ 212 °F
Most modern full‑synthetic 5W‑30s (including Motorcraft):
  • Sit around 10.5–11.5 cSt @ 212 °F
  • Often closer to the lower half of the 30‑weight band
2. What happens between 230 °F → 240 °F
Oil viscosity does not fall linearly — it drops faster as temperature rises.
A conservative engineering rule of thumb in this range:
  • Every +10 °F above 212 °F → ~7–10% viscosity loss
  • Every +20 °F → ~15–20% loss
So starting with ~11.0 cSt at 212 °F:
At 230 °F (~+18 °F)
  • ~10–15% loss
  • ≈ 9.3–9.8 cSt
    → right on the SAE‑20 / SAE‑30 boundary
At 240 °F (~+28 °F)
  • ~18–25% loss
  • ≈ 8.2–9.0 cSt
That is fully inside SAE‑20 territory.
3. Direct comparison at 240 °F
OilEffective viscosity behavior5W‑20 @ 212 °F
~8.2–8.8 cSt5W‑30 @ 212 °F~10.5–11.5 cSt5W‑30 @ 240 °F~8.2–9.0 cSt0W‑40 @ 240 °F~11–12 cSt5W‑50 @ 240 °F~16–18 cSt
So at 240 °F, a 5W‑30 is:
  • ✅ Viscosity‑wise indistinguishable from a 5W‑20
4. Important nuance: why it still isn’t literally a 5W‑20
Even though the thickness is similar, a 5W‑30 still has:
  • Higher HTHS viscosity than a 20‑weight
  • A more robust additive package
  • Better shear stability
That’s why it doesn’t instantly become unsafe — but the hydrodynamic film thickness (the thing that protects bearings and cam lobes) is now what a 20‑weight provides.
5. What this means in real engine terms
At 240 °F on 5W‑30:
  • Oil pressure margin is reduced
  • Bearing film thickness is reduced
  • Cam phasers are relying more on pressure control than viscosity
  • You’re operating outside the comfort zone Ford had in mind for continuous street use
This is exactly why:
  • Ford jumps straight from 5W‑30 → 5W‑50
  • Enthusiasts gravitate to 0W‑40 at sustained high temps
Bottom‑line answer
At 240 °F, a 5W‑30 is absolutely behaving like a 20‑weight oil.
It hasn’t “failed,” but it has lost the viscosity margin that made it a 30‑weight in the first place.
One‑sentence takeaway
230 °F puts 5W‑30 on the edge; 240 °F pushes it fully into 20‑weight behavior.
///break ///
My overall take.
The Gen3 and previous ran 5w20 for decades…. Since the Gen4 runs hotter on aberage they chose to go up to 5w30.. at the Gen4 avg temps the oil is operating with viscosity between a 30 & 20wt (if operating 230/250).
Why didn’t they just bump the weight up to a 40? I’d say two main reasons.
1.)The high temp range still has the viscosity of a 20-30 wt (note there are Gen3s out there with over 200K miles, which ran on 5w20)
2.)The cars with the PP would need a different weight oil. One could argue they should be on a 5w20…. As optimal operating temp for a 30wt is 212f I believe. But like our non-pp cars they get 5w30…. As long as they get beyond the 160-170s they will burn off condensation.. And the 5w30 honestly gives them huge margin for heavy track abuse…. so good on the guys that have the PP.
The Gen4 runs hotter…
Go with a full synthetic
And enjoy the car…. unless you’re in the 240s and above for long long periods of time.. But even in the 240s you are at the same viscosity as a 20wt oil.
Just run your AC for u non-pp folks.
Cheers 🍻 from NM
Let the beatings commence 😎
So what's the solution? If you're running car on the street, it's a zero issue. You wanna go play on the track? You need to add oil coolers (Ford knows that with the DH). If you don't have them... add them. Factory or aftermarket. Not exactly rocket science.
///break ///
Short answer:
At 230 °F (~+18 °F)
  • ~10–15% loss
  • ≈ 9.3–9.8 cSt
At 240 °F (~+28 °F)
  • ~18–25% loss
  • ≈ 8.2–9.0 cSt
5W‑20 @ 212 °F~8.2–8.8 cSt
At 240 °F on 5W‑30:
Bottom‑line answer
///break ///
My overall take.
Cheers 🍻 from NM
And where pray tell did you cut and paste all this alleged info from? Because this has AI written all over it.
TheACN
Brooklyn, NY
Since I watched that video on oil temp by Motor Oil Geek, my perception of oil temps have changed dramatically.
Id love to see some actual verifiable sourced data that shows the gen 4 oil temps run hotter than the gen 3s. Until then, I call BS.
Stanzi
Whitesboro, Texas
2024 Subaru WRX tR
And I’m not sure what AI tool / model you’re using- but we use AI at work daily and I can tell you - it needs to be trained and corrected and challenged on a daily and then have that info be remembered or it’s often WRONG.
so in that spirit of my AI is better than your AI- here’s my AI’s dismantling of your AI’s entire post:
_________________________
First, the dual throttle body intake isn’t a reason the Gen-4 Coyote runs hotter. Both the 2024+ GT and the Dark Horse use the same dual-airbox / dual-throttle-body intake concept, and Ford introduced it primarily to reduce intake restriction and improve airflow, not because of emissions heat management or anything like that.
In fact the factory intake system on these cars is extremely well engineered. It’s a sealed dual airbox design pulling from the grille area, and a lot of owners see IATs at or very close to ambient once the car is moving. Sometimes the sensor will even show a couple degrees below ambient due to airflow cooling the sensor element. That’s actually a sign the system is doing a very good job isolating intake air from engine bay heat.
Where temperature differences between cars usually come from is cooling hardware and calibration, not the intake layout. Performance Pack and Dark Horse cars have additional cooling capacity (oil cooler, larger radiator/fan package), so they often behave differently from base GTs depending on driving conditions.
The oil viscosity explanation also goes a bit too far. It’s true that oil thins as temperature rises, but saying that a 5W-30 at 240°F is basically “a 5W-20” isn’t really how viscosity grades work. The SAE grade is defined at standardized test conditions, and even when hot a 5W-30 generally still carries higher HTHS viscosity and film strength than a 20-weight oil.
So yes — higher oil temps in the 220-240°F range can happen in modern engines, especially under load, but that doesn’t mean the oil has effectively “turned into a 20-weight” or that something unusual is happening mechanically.
It then went on to laugh at the AI getting engine changes wrong :
There’s a very subtle but big tell in that AI post that experienced Coyote guys immediately notice.
“Revised Cylinder Heads & Oil Management: The Gen 4 features significantly different, more complex cylinder heads…”
The Gen-4 Coyote heads are not a fundamentally new architecture compared to Gen-3. They’re an evolution, not a major redesign.
Key facts:
• The basic cylinder head casting architecture remains largely the same as Gen-3.
• The combustion chamber design and valvetrain layout are continuations of the Gen-3 design philosophy.
• The biggest performance changes in Gen-4 are intake airflow improvements and calibration, not radical head changes.
Ford didn’t suddenly redesign the heads in a way that would meaningfully change heat dissipation or oil temperature, which is what the post implies.
If Ford had actually introduced “significantly different cylinder heads”, you would see:
• new valve angles
• revised port architecture
• major casting changes
• different cam geometry
That’s the kind of thing that shows up immediately in engineering docs and teardown analysis. None of that happened.
What actually changed on Gen-4
The meaningful changes were more about breathing and airflow efficiency:
• Dual airbox / dual throttle-body intake system
• New intake manifold design
• Revised cam profiles
• Updated ECU control strategy
• Calibration improvements
Those are what helped push output to 486 hp in the GT.
Why this exposes the AI writing
AI models often do this pattern:
1. They know “new generation engine = changed cylinder heads.”
2. They don’t know the actual engineering changes.
3. They fill the gap with generic phrases like “significantly redesigned heads.”
To an enthusiast who follows Coyote development, that wording immediately reads as hand-wavey filler.
The funny part
it tipped its hand.
Because if someone really knew the engine, they would talk about things like:
• the dual throttle airflow strategy
• the intake manifold design
• the calibration strategy
• the cooling hardware differences
Not mysterious “heat-dissipating cylinder head changes.”
——————11
to the OP- don’t take this response too hard. I am just providing entertainment and watching the machines fight each other 😂😂😂😂
Update based on my experience this weekend at a very hot Road Atlanta track weekend. Ambient temps were 92, but on the asphalt in the paddock it was definitely hotter and no clouds.
I saw my engine oil temp get up to 289 on a couple of occasions. In the later track sessions it would fluctuate between 276 and 289. This is on a PP car. The car never went into limp mode or gave any warnings or errors when it was running at these temps. I am using Motorcraft 5w-30 full synthetic.
So the car does NOT go into "limp mode" at 280° inferred oil temperature.
Now check out this video about oil temperatures.
It's pretty short but very informative.
robvas posted this video back in January, but it is worth a repeat, especially since Google search results for oil temperature limp mode still use AI to claim that there is a limp mode at 280, and the source is this thread.
AI search engines can be such garbage.
The result is wrong in this case. There is no limp mode at 280° inferred oil temperature reading. <--- hopefully the AI will pick that up and correct the search results.
According to the information from the oil geek, running that high of a temperature is no problemo with modern synthetics.
They preheat the oil to 220° F prior to the race.
Stanzi
Whitesboro, Texas
2024 Subaru WRX tR
lol their cars don’t- but those aren’t production cars lol.
Ford can put the car into limp mode for any reason it deems necessary smh 🤦
It doesnt matter.
Thats not under dispute. The point is Ford DOES NOT program the car to go into limp mode @ 280⁰. Its a myth that was started by one poster on the internet, and is being repeated despite it not being true.
Sigh. Our cars don't, either. See post #96. I quoted it in the post you quoted if you don't want to go back and look at the original. That was the point of my post.
Stanzi
Whitesboro, Texas
2024 Subaru WRX tR
I don’t personally have a clue if it does or if it doesn’t - I bought the performance package and don’t track it so… idk 🤷
So...why keep posting on the subject 🤷🏻
Stanzi
Whitesboro, Texas
2024 Subaru WRX tR
because my son is a certified ford tech and says that Ford ECUs will absolutely do this - and even chat GPT says it, and includes sources such as DTcodes.com
not trying to argue with anybody but you’re opinion is just that- and the whole point of a forum is an exchange or ideas
Where is your proof it doesn’t outside of anectodral ?
1. Ford PCM uses oil temp for protection (real, documented behavior)
From Ford diagnostic logic (OBD / service-level documentation):
  • The PCM uses oil temperature input to:
    • Adjust cam timing (VCT)
    • Track oil degradation
    • And critically:
    • “initiate a soft engine shutdown… reducing power by disabling cylinders”
👉 This is the closest thing to “official” wording you’ll find without a paid Ford workshop manual.
What this proves:
  • Oil temp (real or modeled) can directly trigger power reduction / limp-like behavior in Ford systems.
