So0_NaSTy
NY
2024 Ford Mustang GT Premium
Probably not. Unless it is supposed to work and the module they sent you is misconfigured from them? Hard to say, but worth a phone call at least, imo.
I can inquire. Thanks for the help
Luis S.
Austin TX
2024 Mustang GT PP1
I am looking for someone in the Austin/Central Texas area that has and knows how to use Forscan . I need to disable fake exhaust and also add a Boost gauge . I will pay for your time .
yeti.5oh
Bulverde, TX
2024 GT premium 6MT
I’ve figured out how to get rid of the pinkish-orangish tint on the drl’s after switching to the dark horse welcome light show. For both 6F7-05-06 and 6F6-05-06 you’ll want to change X*XX to the number 7. Once you do that you’ll notice XXX* will change to a letter, for 6F7 mine changed to an F, for 6F6 it changed to an E, which is correct for the dark horse as-built that I pulled.
What module is this change in? the BCM? I figured it was the headlight tint making that color! Thank you X100000
So0_NaSTy
NY
So my forscan is on a version from December of last year and there’s plenty of updates since then and upon them I’ve heard that modules have changed and they may not be the same as my current changes and / or saved build sheet. If I update forscan will all my current saved as built modules be useless? Because the modules that were changed that I try to revert are now completely different?
D/\rK•650
2025 Mustang DarkHorse
So here is my thoughts on this.
No, your updating Forscan, it reads the modules and your saved build modules files are the same as before. Forscan will see that and act accordingly.
mabcim
Rochester, NY
In case you don’t know, you can get all your original values from here: https://www.motorcraftservice.com/AsBuilt
BimmerDriver
RDU, NC
BMW M3 w/3 pedals
I'd like to turn off the ESE in my car, anyone in the RDU area who can help me? I will be happy to pay for your time in beer or even money... :wink:
rugedraw
Miami, FL
mabcim
Rochester, NY
Keep in mind that these newer connected vehicles sync up with the server eventually and whatever changes you make will eventually make their way up to the cloud and become your new ab value(s).
I did not know that. That could explain why sometimes Forscan changes don’t get wiped when a module is updated at the dealer.
npole
Italy
Mustang Dark Horse 2024
More than "some times".. it's "most of the times" (the opposite: AsBuilt not being updated is less than the times it gets updated before a new update is pushed out):
https://www.mustang7g.com/forums/th...remote-servers-right-before-an-update.167374/
The only way to preserve (partially) the AsBuilt data of your vehicle, is to download offline everything before starting the changes, so they can be reverted. And neither this is enough, because sometime the changes in the settings are legit (pushed by Ford) and not because of a ForScan modification.
mabcim
Rochester, NY
I download mine, from the website, right after the vehicle is built. And then save in Forscan not too long after getting it.
I knew updates from Ford get updated on the website as time goes on, but thought that was a dealer/Ford thing. Never thought the car would upload any changes we did to it.
Luis S.
Austin TX
2024 Mustang GT PP1
I am in San Antonio and would be more than happy to help.
I can drive down any most any Saturday or I am off all of Xmas week. Let me know when it would be convenient for you . I really appreciate it.
SPANKY
Seneca, SC
2025 Dark Horse Premium S5806
Looking for setting confirmation from either DH or GT PP for the attached two files. I have a Non PP GT and need to compare the files with that of a DH or GT PP. This is in relation to the inferred oil temp algorithm and the addition of the oil cooler to Non PP Mustangs. For additional clarity, FP and HPTuners have confirmed the alogorithm is generated in the BCM and not the PCM. The current belief is this could be addressed through settings within the BCM.
Were you ever able to get this info?
sky5oh
North Carolina
Fantastic. I swapped my headlights for autoaddict RGB’s, and auto doesn’t activate. So I wanted to check if there’s any codes and if not, maybe disable it and then re-enable.
This is a known defect, they all come from the same Manufacturer overseas. I bought mine from Stanglights, the issue is more than likely the Passenger Side Headlight. It should be fault code: “B14DC-87” the driver side RGB for mine works as long as the oem headlight is plugged into the passenger side. Stanglights is sending me out a replacement set and I’ll be sending my current ones back to be R&D’d. So far I’m now aware of 4 total people having this issue, including myself.
