GrabThatBlue
Between Canada and Europe
OK i figured it out, i did as above and remote rev works (this is with a 3 button Key Fob) i use the Ford app to remote start
, Auto DH , Spain ...im just trying to find spreadsheet now for reverse tilt mirros and global windows opening shut
Global windows close will not work.
npole
Italy
Mustang Dark Horse 2024
Fruitstang
2024 Mustang GT Convertible
I tried every parameter in every module that hinted to that functionality - with no success (European GT).
A.alansari
Qatar
Mustang GT 2024 PP
this is what i have been looking for , i have been trying for the last few weeks how to enable remote rev, as there is no option in the *easy* mode forscan, could you please tell me what code it is under , thank you in advance or better still a screenshot
it should be this
remote revPCM7E0-162-04x2xx xxxx xx--
A.alansari
Qatar
Mustang GT 2024 PP
for the reverse tilt someone here have this genius idea
save seat 1 to what you like to drive
save seat 2 to the same and just tilt the mirrors to what you like so when you need it you just press the seat memory button 2 when done you press 1
5.0ALM
Brisbane, Australia
So0_NaSTy
NY
2024 Ford Mustang GT Premium
Anyone happen to know the line for the auto high beams?
rugedraw
Miami, FL
It's in several locations. HCM, SCCM, IPC, APIM and BCM all have config that is relevant to auto-high beam asssit.
So0_NaSTy
NY
Fantastic. I swapped my headlights for autoaddict RGB’s, and auto doesn’t activate. So I wanted to check if there’s any codes and if not, maybe disable it and then re-enable.
rugedraw
Miami, FL
Not familiar with the product. Does it require a different headlight module or is all the OEM stuff retained and it's just a headlight assembly? Does the vendor say AHB is supported with their product?
I think checking for codes is a good start.
So0_NaSTy
NY
According to them, it should retain OEM functions. It comes with the module installed in the back and all, so it may be that. But it is plug and play.
rugedraw
Miami, FL
I think you should try contacting them first. AHB is configured in the HCM here, but there is no reason why that config would have changed on its own to disable the feature just from installing headlights.
So0_NaSTy
NY
I think it’s their module. You know the silver module in the rear of the headlight? The RGB’s came with their own. I assume it’s that. Nothing I can probably do tbh
rugedraw
Miami, FL
Probably not. Unless it is supposed to work and the module they sent you is misconfigured from them? Hard to say, but worth a phone call at least, imo.
