Forscan
So0_NaSTy
NY
2024 Ford Mustang GT Premium
Hello all. Curious if any of you experimented with forscan on your 2024. Any cool things you somehow found? Anything interesting?
I also ask because I’m trying to figure out if anyone knows a way to disable the auto stop start without causing an issue. I know in IPC easy settings, you can disable it, but it does nothing. All it does is disable the light on the dash, but it still works.
jboogie1289
Friendswood Texas, 77546
@roadpilot
@rugedraw
@Zig
@roket
Those Forum members plus a few more that I missed all have had posts on here about use of FORScan as well as links to other sites that are useful.
rugedraw
Miami, FL
So0_NaSTy
So0_NaSTy
NY
rugedraw
Miami, FL
How do I reboot it? You mean just write it? Also, I’m assuming then that setting is in the PSCM spreadsheet?
Write the change, then go to the wrench icon and reboot the PSCM. Yes, I got that from the spreadsheet here for these cars.
rugedraw
Miami, FL
Can someone explain forscan? Software? Hardware? How to purchase?
FORScan is software. $12 for 1 year license. The adapter you need to use it is below:
Vgate vLinker FS OBD2 USB Adapter for FORScan HS/MS-CAN Auto Switch https://a.co/d/iV40SLK
You can find tutorials online or on YouTube for FORScan.
So0_NaSTy
So0_NaSTy
NY
Update: doesn’t work
coolest thing i found was the 220mph speedometer, but it does not work properly. probably works right on 2025s because the GTD's speedometer is 220mph. the most interesting thing is probably the Beosound menu, even if it also doesnt work. my favorite thing is something that actually does work, the performance shift indicator
So0_NaSTy
So0_NaSTy
NY
That’s not really useful on autos I assume though? Shift indicator?
i find it useful when im going full throttle. i have it set to 7000, and shifting there ensures i dont hit the fuel cutoff when accounting for shifting delays
So0_NaSTy
So0_NaSTy
NY
You have a 10 speed? I mean I assume it’s okay for manual mode but I’m not sure. Where is that to enable it?
IPC and APIM. APIM calls it "performance shift indicator". IPC calls it both "performance shift indicator" and "shift indicator"
So0_NaSTy
So0_NaSTy
NY
Hmm. Anyway to enable launch control on an auto?
So0_NaSTy
So0_NaSTy
NY
also for both of these, which numbers do I put in to replace the factory ones? It’s another one of those with like 10 options and I have no clue what’s correct. Also finding it in IPC was difficult because it shows “upshift” or “downshift” indicators, unless it’s both that must be changed.
