petemossmorrone
NY
2016 ecoboost conv.
Thanks..I did..I guess what i am trying to understand is how do we know if the codes in the spreadsheet are verified for this car or just carried over from some other source spreadsheet.
Slothman
2024 Ecoboost Vapor Blue Nite Pony
I have been trying to enable remote-rev on my 2024 mustang w/o active exhaust. I found the line in the PCM configuration. Has anyone been able to modify the PCM or has ford locked it down? I keep getting an error when i try to write to it.
You don't. Using FORScan to mod all these values isn't plug and play, especially early on. Until someone tries something out, reports back, and the spreadsheet is updated, nothing is guaranteed.
DaddyTigggs
New Jersey
2024 Mustang EcoBoost Conv.
After you remote start the car, are you letting the RPMs wind down to under 1000? You have to let the car get to a low idle before you can remote ref.
Tafische
Tennessee
2024 Ford Mustang Premium Convertible
I have been looking at a couple of options to play with...I am new to Forscan and not ready to push the write button yet.
Has anyone played with Feat_Cfg [WALKAWAYLOCK] [VEHICLE] (WALKAWAYLOCK_VEHICLE) in BCM?
Every other FOB vehicle I have had locks when walking away.....any luck getting this to work?
rugedraw
Miami, FL
This was just added to the common tab of the spreadsheet. All credit goes to Livnitup for the changes needed. I also would like to thank @roadpilot for being the guinea pig to test this out.
Edit: As noted in the spreadsheet, this will only work on job 2 Mustangs; job 1 cars will need to have the BCM updated. As far as I know, the BCM updated has not been sent to any Mustang yet via the OTA process even though every VIN I have checked shows a BCM update pending on the server for these vehicles. I am not sure what the cut-off date for job 1 and job 2 cars are. If you have any doubts about whether this will work on your car or not, feel free to message me your VIN and I can check for you. The BCM must be at software level NU5T-14C184-AAT (or higher) for this to work.
mrnavy2
Central NJ
2024 Dark Horse Oxford White,
How do you know if I have a Job 1 or Job 2 Mustang?
As @rugedraw said, post or send him your VIN and he can look it up.
I have a Mongoose-Plus and grabbed an FDRS 2-day subscription to update my Dark Horse back at the end of April. That's how I updated my BCM, and why Walk Away Lock works for me. That said, my DH is a Job 2 Mustang as well.
I also enabled Auto Relock. This is pretty cool. If you unlock your car with the remote, but then you don't actually open the door (e.g., accidentally unlock it or maybe your kid was playing with your keyfob and unlocked it), the car will automatically re-lock itself after 30 or 45 seconds (you can set it to either). Not sure if it was added to the spreadsheet or not, but it works.
ChrisMattice
Albany NY
2017 Ford F150 XLT
Has anyone started playing around with flattening the EQ on ACM 727-01-02 on the 650’s yet? I have a 301a 9 speaker setup that I want to try to liven up a bit and this was a good fix on my 2017 F150. I’m going to dust off my OBDlink MX and renew my license soon…
FYI this is what I’m referring to:
727-01-02 x*xx. 0=Flat EQ
1=Premium EQ #1 7=Audiophile EQ#3 D-F=misconfiguration
2=Premium EQ #2 8=Audiophile EQ#4
3=Premium EQ #3 9=Audiophile EQ#5
4=Premium EQ#4 A=Audiophile EQ#6
5=Audiophile EQ#1 B=Audiophile EQ#7
6=Audiophile EQ#2 C=Audiophile EQ#8
Update:
The spreadsheet is indicating the number is in a different spot now. This is the one listed for the 2024:
727-01-02xxx*xxxxxx--0 =EQS Flat EQ7 =EQS EQ #7
1 =EQS EQ #18 =EQS EQ #8
2 =EQS EQ #29 =EQS EQ #9
3 =EQS EQ #3A =EQS EQ #10
4 =EQS EQ #4B =EQS EQ #11
5 =EQS EQ #5C =EQS EQ #12
6 =EQS EQ #6
RaceRedder
Houston, TX
Dark Horse HP
Does anybody know if it's possible to change MPH (USA) to KPH (rest of the world) in Forescan?
I know that you can change MPH to KPH in the menu settings but that's not the same as the MPH still is shown and the screen looks to busy.
rugedraw
Miami, FL
Possible good news for those that want to enable walk-away locking, but I would need a guinea pig to try it. A few of you have messaged me to check what software your BCM has on it and until today, everyone was on the AAS version. However, another member now asked me to check his car (very early build date of July 2023), and his BCM is on AAR software. My theory is that those of you I told could not do it because you were on the AAS version CAN enable this feature.
Question is: Who's gonna test it out?
What version is mine?
