Sync system issues
sdsteele2
Tennessee
24 Mustang GT
So here’s an update. I did a little checking and noticed that my battery voltage seemed a little low around 12.4v. I put the battery on my charger and it estimated the charge at ~80%. After letting my charger top up the battery and doing a reset I have not had any issues.
I know a lot of electronic systems are sensitive to low voltage. I suspect that this may have been my issue. Especially since the reboots all happened shortly after startup when the battery had just taken a hit from a cold start.
Best guess, sitting around for a couple months left me with a weak battery and it needed a good charge. I will have to keep an eye on it in case it’s just a faulty battery.
Does this mean around 72 days is as long as you should go before plugging her in or taking for a nice ride?
FWIW, a reference from the inspection checklist: "With the ignition key in the OFF position, check battery state of charge. Recharge if indicator is red or voltage measures ≤12.4 V."
New car, generation, systems, software, post-production delays, etc.
When I receive a new computer, I'll plug it in, turn it on, and let it sit for 24+ hours before doing anything else. They often go through a series of patches and reboots before stabilizing.
I reviewed the inspection checklist for newly received vehicles, the document the dealer is using. I do not see any statement related to systems, software and patches.
Not saying that is the root cause of this example. As modern as cars are now, seems it would be worthwhile to confirm internal software, electronics and systems are updated and operating correctly, as part of the initial checkout by the dealer.
sdsteele2
Tennessee
24 Mustang GT
Not saying that is the root cause of this example. As modern as cars are now, seems it would be worthwhile to confirm internal software, electronics and systems are updated and operating correctly, as part of the initial checkout.
That's a good point. I did run the update check the first night I had the car, and a few times since. No update as yet.
I'm guessing they forgot that step on the PDI 🤷‍♂️
sdsteele2
Tennessee
24 Mustang GT
That and probably a bunch of cold starts and short drive being shuffled around storage lots and what not.
I usually hook my cars up to a battery tender if they are going to sit more than a week or two. I wire up a quick connect lead to the battery so it's easy for me to do. Is it overkill? Probably, but it makes me feel better. :crackup:
I'd seen that, yes.
I updated my post. Apologize if I implied this should be done by the owner/operator.
Hopefully, the "settling" period of these car/s and their systems is a brief one.
sdsteele2
Tennessee
24 Mustang GT
I'd seen that, yes.
No offense taken. :thumbsup:
TTown
Tulsa, OK
Previous - '19 GT, '24 ZL1 - Next, '25 GT, DH?
Talk to Ford ASAP. This should not be happening on a brand new car IMO.
If I didn't know any better I'd dare to say that they sold you a prototype. Should this kind of thing even be happening??
It's amazing isn't it. All of the Ford apologists will excuse it, look past this stuff, etc. 2024 buyers better get ready for all kinds of shitty problems to surface. They are coming.
What I'm curious to see is if the infamous BBQ tick comes back.
Jrws1014
North Carolina
I picked up my GT on Friday and the only issues i have had so far with the infotainment system has been one, i got a message while my music was playing and it cut out audio for everything, had to turn the car off and back on to get it to go to normal and two, i have had the right screen not turn on when i started the car but the gage cluster screen did, again a restart of the car and it was back.
I fully expected glitches with such anew system and it all being digital now, I'm very happy that there will be OTA updates provided by Ford every so often to smooth out software bugs.
We’re you use of Apple CarPlay? I noticed things like that with the sync 4 system on my wife’s expedition.
Carter1776
Indiana
2024 Mustang GT Atlas Blue
Android auto, 2 weeks in now and I haven't had any other issues so far.
Dena
Phoenix AZ
Normally that shouldn't be a problem because solid state electronics are either designed to run over a wide range of voltages or they have some type of regulated power supply to condition the voltage. That said, getting the last 20% of the power in the battery is a slow process. During that part of the charge the battery can't absorb the power at the full rate so the charge takes much longer than expected to top off the battery. The solution is either a charger as you did or a very long drive. What is puzzling is the alternator should have delivered enough voltage to avoid the problem. You might want to check battery voltage while the car is idling just to make sure the alternator is functioning correctly.
Jrws1014
North Carolina
Stratman397
Seneca,SC
Figured I get the ball rolling on issues with the Sync infotainment system. And brace for the “never buy the first of anything 😁.
Picked up my GT premium on Thursday. I have noticed two issues with the new Sync system. First, if I configure the user profiles the car will not remember all of my settings/preferences between restarts and it always defaults the gauge cluster to Track gauges, but not track mode.
Second, the entire system has just rebooted three or four times while driving the car. It seems to be mostly on or shortly after startup. The screen goes blank. No backup camera. No response to the center stack buttons. Nothing.
Has anyone else notice any strange behavior? I’m going to try a system reset tonight. If it continues I’ll probably get to be the first s650 in for warranty repair 😪
This is what I said from the get-go, and of course I got all kinds of hell for it on here. But my husband he got the first body change of the Honda pilot, And it was a problem after a problem.
Now another problem is all the stuff in the car’s. In a lot of mechanics have no clue how to even work on them anymore. But sometimes one problem leads to another and another, etc. etc. I would get it back in like ASAP.
Stratman397
Seneca,SC
I have also noticed that and that my profile is also not saving the settings properly but no systems reboots as of now
I never had a car with all that stuff in it, but I sent one of those profiles for my husband and myself, and I know that the seat going back-and-forth when you unlock the door only works for whatever person you got it set on.
I only had mine when I set it up so when my husband was driving the other day, a lot of things were coming on that I had turned off, so then we realize that we had it set over on his, and had not set it up all the way yet, so I’ll go out there in a little bit and get his taken care of. The one thing I do like about it,of course I turned mine off was to check to make sure nobody was still in the backseat. People that forget they have babies in the backseat need these cars. I’ve never once forgot my kids in the backseat.
