Issues with my s650 infotainment system, collision system, brake squeaking, and car suspension
DukeCLR
Vermont
My Mustang felt very light in the front, it felt like it was floating, I think it was the lane assist, I turned it off. My tires were also slightly over inflated, I made both these changes at the same time. The front felt much better.
IFFV68
I have a 2024 mustang GT premium I was one of the first guys to get it delivered back on August 2023. My vehicle only has 5100 miles and I have major issues they’re very replaced the CarPlay module and the front and collision parts on the beginning of September 2023, because the Apple CarPlay used to disconnect or not playing any music now I’m having the same exact issue all over again.
The issue is the collection system it constantly shows orange when nothing is blocking it in the car is freshly washed
also, the brakes squeak and when I’m stopped, or I’m trying to turn, it, sounds like the suspension is squeaking or the steering wheel
Lastly, when I drive pretty fast, anything over 100 mph, the vehicle seems to go left and right left and right almost like it’s loosing control or when I’m doing a turn at over 60 mph, which a car like this should not be doing that not even my Honda does that
You may need to add an Engine Strut to tighten up the Front End.
I had an Atlas Blue 2024 Gt Premium without the PP.
I added an Engine Strut & it steered straight down the road.
My new Rapid Red 2024 GT Premium we took it up to Central City Co to do some Gambling.
Part of I-70 has been under construction for over a year.
Our 2024 GT Mustang was all over the road.
I have the Engine Strut Tower, Cowl Brace ordered as we speak.
I believe it’s well worth the Money.
I know it’s Subjective.
Zeeku22
Utan
S650 gt premium 10 speed
Ive been messing around with my 650gt for about 6 months now, and have gone 14,350 miles since i got mine brand new, got everything setup the way i want it through a combination of Forscan and physical experiments.
Ive run across alot of issues and fixes for those issues along the way
If you get collision warning after a wash typically i found the water would get on the forward rader under the middle of the front bumper which is responsible for emergency braking. water may distort the radar signal and cause the car to think its raining, so it temporarily disables collision mitigation to prevent hard braking in bad weather. (Note: frost can build up on the face of the radar cover and cause collision mitigation to temporarily be disabled)
The brake squeak can be a number of things but is likely dirty rotors and/or callipers, possibly overheated rotors or brake pads.
The front end is typically a combination of tire ware and air pressure.
If you increase pressure from where the tires have been worn the steering will become lighter as less surface area is on the ground, if you decrease pressure the steering becomes heavier because more surface area is on the ground.
(Note: air pressure changes with temperature, and tires can expand at speed. At above 100 mph aerodynamics and downforce becomes a factor.) Hope this helps
