Refueling is difficult
Ducatti20
Phoenix, AZ
I will have to try. Unfortunately, no other gas stations around here have high octane gas (94). All others in my area have just 91...
Yeah I totally get that. I think the key for you is verifying that the car is OK vs a pump issue. If it happens at multiple stations I'd be bringing her back to Ford with some data showing there is an issue.
Sig Oris
Western Maine
Hey all.
I have refueled my new Mustang GT three times now. Two of those times it was very difficult. Even when I’m only squeezing slightly it’s still clicks off every a few seconds. I’m not sure if I’m not inserting the pump for enough, or insert to get too far, if I’m doing something else wrong.
And I’m not sure why once it worked fine.
I have been driving and refusing cars for half a century. This is the same gas station that I use for my Audi, so it’s not likely to be the pump.
What am I doing wrong?
I’d refer to the UCMJ on guidance for penetration
Starship Enterprise
MD
2025 Mustang GT Premium
These cars have something like a twin saddle tank. if you pump too fast, back pressure prevents the gas from getting to the other side. Then the pump clicks off thinking the tank is full.
If you pump the gas at a slower setting you'll be OK.
Every pump can be different, and weather temp is a factor too.
Hey all.
Have you tried different gasoline stations? Like a totally different one than you normally use?
mwillems
mwillems
Ottawa
2026 Mustang GT convertible, standard
I have not yet. Because this station is th only one in the area that has gas higher than 91 octane (94, in this case). But I have been filling up my other cars at this station for years.
Still, it's a go0d suggestion and when I do find one that has the right gas, I will try.
mwillems
mwillems
Ottawa
On my dark horse, I had the same problem. Turn the nozzle to 3 o’clock or 9 o’clock position and it will fill up just fine. At least for mine it did.
I will try that next time!
Ken H.
Wyoming, DE
Flipping the nozzle is the solution! I’ve had this problem. Someone in this forum suggested flipping the nozzle 180 degrees. I tried it. PROBLEM SOLVED! Can’t speak to flipping 30 or 90 degrees but I’m gonna try it.
OmegaDH
Denver
2026 Mustang Dark Horse - Shadow Black
Surrender your vehicle to the nearest pedestrian with a brain. Then hang your head in shame. :rockon:
mwillems
mwillems
Ottawa
Not called for. I have been refueling many, many different cars, as well as motorcycles, boats and airplanes for over 50 years, and I have NEVER had problems like this. I know what I’m doing.
You can put 91 in it for one fill up... unless you have a tune that doesn't like that... just to see if it is a problem with the car itself.
OmegaDH
Denver
Have you check your back left tire? Could be the problem.:thumbsup:
