Well. warmer weather is "sort of here" in Almost Canada....................time to quit slacking and get my DIYVan fender liner blocks installed.
Got almost 5400 miles on the GT (VERY few dirt/gravel miles), but I'm still planning on dropping the under trays to see how much road grit accumulated in them. And, to check the condition of the leading edges of my unit body pinch rails.
Won't be surprised to see some bare metal due to the road grit (if not; that's a plus!), so I'm planning on using this to cover any bare metal/rust that may be present.
https://www.amazon.com/Rust-Oleum-2...&hvlocphy=&hvtargid=pla-4583657826363376&th=1
I selected the rattle can version of this as the regular "brush it on can of it" is $30. vs $9. for the rattle can.
Thoughts, comments, advice, alternate product suggestions? TY!
Same here in NY.
PonyKing
S650 GT
I also came up with my own (I think) neat and most convenient available fix for this problem. Apart from removing a screw on the underside of the vehicle, the installation literally takes 10 seconds.
I recorded a short video showing the full installation process.
If you're interested you can hit me up as well!
Cobrakit
Southern Maryland
2019 Mustang GT PREMIUM PP1
Ok, so are you making these to sell ? How much ?
VileKnight
DFW
2025 GT
It’s amazing that Ford let this off the assembly without putting something over the gap, but thankfully we have an easy fix. Ordered my kit tonight!
8915GT
Looks good, how is it holding up with only on screw holding it in?
PonyKing
S650 GT
It's not just the srew holding the part, there's also a groove at the top that slides into the actual wheel well which also holds it via friction. I had a 125 miles Autobahn ride yesterday which was reaally bumpy and it stayed in place.
S650 Mustang Patched My Fender Well Holes - DIY Instructions & Photos Part
8915GT
very nice, is there a website you are selling these on?
Dzm13
GB 2024 GT PP, MR, AE, 401A
I think it's a brilliant, well executed solution, bravo! Sent you a PM
DT-GT
2022 Mustang
I just used the DIYvan kit to patch the inner fender holes. Easy. Perfect fit. Really made it easy. Glad to get this done while my car has only been driven a few miles from dealer to home. Very pleased!
Billycar11
Got Mine from him and fits perfect no messy glue 5 mins per side and your done fits perfect just follow the video he posted 1 bolt holds it all in and has a slot for the fender liner.
S650 Mustang Patched My Fender Well Holes - DIY Instructions & Photos 1746574055363-iy
Dzm13
I bought these and installed. I was hesitant to mess with glue/jb-weld stuff and really glad I didn't go with the other solution.
Install is super simple on the garage floor, 10 minutes max. They stay in place, look good and mod is 100% reversible what I personally like a lot. Purchasing process was also top-notch. Recommend!
They are dirty on photos because they work! Photos are made couple of weeks after install.
S650 Mustang Patched My Fender Well Holes - DIY Instructions & Photos 20250512_133919
S650 Mustang Patched My Fender Well Holes - DIY Instructions & Photos 20250512_141029
