Billycar11
Can those be painted over? Can you link those products?
no they cant be painted over its an oil coating that prevents rust and stops it
https://www.homedepot.com/p/Blaster...on-Protectant-Lubricant-Spray-16-SS/316548568
https://www.lowes.com/pd/Fluid-Film-11-75-oz-Lanolin-Based-Petroleum-Oil/50335157
https://www.acehardware.com/departm...rication/penetrating-oils/8069220?store=14671
https://www.woolwaxusa.com/Woolwax-12-oz-Aerosol-Spray-Can-Clear-_p_1.html
its all pretty much the same surface shield and wool wax are thicker so last longer but not really an issue you since it will no longer begetting wet or hit
check out repair geeks videos on all the undercoatings
TheGrabberBlueGT2024
Awesome. Yeah once I get franks parts I actually planned to seal the hole with some sort of RTV to ensure it’s locked for good. You will have to excuse all the questions but you said these prevent rust what about the surface rust that looks like it’s already there? No scuffing needed? Just spray this and walk away? Just wanting to ensure I really do my due diligence before I close everything up.
Billycar11
yeah these stop rust as things can only rust with access to air and water the oil displaces that so it cant happen
and no prep needed
and no prep needed
Well this just made this easy. Based off the photos I posted what product would you get? Just finished his video. It looks like surface shield is the top dog
Billycar11
they are all similar the lanolin based ones get whatever is cheapest/easiest to get in your area all home depots have surface shield i think at least up north
Sending you a DM
You are operating under the assumption that Ford cares anything at all about this. If the inner liner has changed its due to a process change, not anything we've said here or complained about.
All that has happened is that there is now a flap rather than a hole for when the car is on the line - it is supported there during the build.
Surface shield appears to be pretty legit that’s what I will be using then putting franks product on it for coverage.
With those products you must decant it into a container NOT brush from the pot or it ruins the rest of it as rust flakes get into the pot. Brush will wash in water afterwards.
Already ahead of you surface shield is what I’m gonna be using. With some sort of applicator
You must use the rust treatment first or you simply seal in the rust and it carries on underneath
It can be applied directly to rust. It encapsulates it and inhibits further damage it’s pretty incredible
