Oil catch can YES or NO?
LethalPerformance
Fl
When do you anticipate having a fully developed catch can for the gen 4 Coyote? I'm very interested in getting one from y'all.
As soon as we have a car local we'll start working on it. Hopefully cars start shipping later this month or next.
LETHAL
From the D but in the NC
From the D to NC
so the catch can is less of an issue as port injected fuel will wash the valves
it's to catch the blow by going back into the throttle bodies more then anything. I run one on every vehicle I have.
Smaaron
Tucson
2015 Honda Accord
Doesn’t the latest coyote have port injection at low rpm’s blended to direct injection at high rpm’s? Would that make a difference?
LETHAL
From the D to NC
Gen 3 had this as well. I'd get a 1/4 canister full of spray every 3k.
NS90
GFY
GFY
What's the general consensus on if the S550 catch can offerings will work for the S650?
Aramis76
Mustang
The fact that it's dual injection doesn't mean it won't have any, it means that the fuel being injected should wash the valves.
LETHAL
From the D to NC
Which has zero to do with the need for a catch can. I don't believe I was contesting the info you just shared?
LETHAL
From the D to NC
Hose routing will be the main difference, MAYBE
Aramis76
Mustang
Of course, I didn't say you were. But the need is not as great as in a direct injection only engine.
LETHAL
From the D to NC
5.0ALM
Brisbane, Australia
I'm on the fence regarding a catch can.
I'm also acutely aware this is one of those polarising subjects which can induce hissy fits.
Qualified independent people debunk catch cans as uneccesary on dual port engines, yada yada.
Retailers and their influencers (those who make a financial gain) push them as must haves.
But this is the first time I have seen reference to crankcase pressure build up, compromising the rear main seal, resulting in oil weep.
I like the simple ways these two prove the catch can is actually causing pressure build up.
(It's only 10 minutes)
Yes, it's an old 80 series diesel cruiser, but back pressure is back pressure, right?
Have their been any long-term reports of Coyote rear main seal issues after a catch can has been fitted?
Aramis76
Mustang
I'm not a fan of catch-cans, but if installed properly, there is no pressure retaining in that circuit, unless you let it fill with oil entirely...
Also that catch-can is a filter, most ones i've seen are a metal mesh. Very different concept.
The metal mesh can't clog up (unless you never, absolutely never clean it).
Ryunker
Madison South Dakota
2013 convertible, 1971 Mach1
Crankcase pressure is a real thing, and does cause oil leaks. That being said, I see this on many GM 4 cyl turbo motors mostly due to a shit pcv designed system. My experience are with todays oils along with a maintained pcv system I see no issues with pressure build up.
With any added catch can the added maintenance item comes with that. It must be serviced (drained) or it is useless. Very similar to K&N replacement air filters. Many are installed and never serviced (cleaned), that causes issues.
On my new ride if it ever gets scheduled, no such catch can will be installed.
It would seem ford finds some value in one, dh seems to include one. At least according to the pdi checklist?
Nv6974
Saw that! Curious to see how that one looks!
Reactions: Zig
