Oil catch can YES or NO?
CoyoteChubbz
Tennessee
Toyoto 86, F150
I don't think there would be a strong need for a catch can, the coyote has Port and Direct injection to fight off the carbon build up on your valves.
since its in there with the gurney flap tells me that its probably only recommended if youre tracking the car, but not needed for every day use
In that case, throw it in the trunk when you do the gt pp, thank you very much. hopefully the clip issue is resolved. Should really be a simple hose swap and snap in place but who knows what they did.
Dena
Phoenix AZ
From what I saw elsewhere, the gurney flap is extra so I don't expect one with mine. In addition, the gurney flap was not recommended for street use so you leave it in the trunk until you get to the track.
unfairslide
Not sure if you're referencing the gurney flap or the catch can, but neither come with the GT. Only the DH.
Catch can, acknowledged and hence the request it be included in the pp. truth be told I’d rather have the can for the gt pp than the strakes.
Nv6974
Mustang GT
So if you do buy the catch can do you get one for both sides?
Depends on the application, however, for the most part, most do the passenger side only.
Agreed.
Street driving with occasional track, passenger side only.
Track enthusiast, tracking often, both sides.
Forced Induction or turbo, discuss with the vender.
  • Like
Reactions: Zig
sdsteele2
Tennessee
24 Mustang GT
What is the reasoning for passenger side only? I have seen that mentioned before but I never understood why the passenger side produces more.
I think, nothing more than convenience. To install the can, you'll disconnect and remove an existing PCV-related connection, one from the passenger side.
For tracking, the car is moving around, things sloshing (LOL) around, high G and RPMs, more severe duty, etc.
For FI or turbo, some can have unique designs, setups and installations.
The guys down under put them on the drivers side…..
Plumbing, vacuum… although tbh, until we see what the dh can is like and how its plumbed can’t say for sure…..
sdsteele2
Tennessee
24 Mustang GT
With the dual throttle bodies, I have noticed that the drivers side head vents to the intake ahead of the driver side TB. The passenger side vents info the manifold behind where the TBs are mounted. I wonder if that will have any impact on catch can placement.
timd38
Hudson WI
Owners manual says to add one if you track the car, or run at high RPMs consistently.
Nv6974
Mustang GT
It would be nice if someone came up with a one can system for both sides, basically dual intake and dual exhaust!
