Catch Can or delete PCV
Deleted member 17846
Guest
A Positive Crankcase Ventilation valve isn't a catch can. It is intended to pull exhaust gasses out of the crank case. A catch can is intended to remove oil that might be in those gasses.
I know what it does. Was responding to your last comment of "Otherwise it probably doesn't make much difference."
Since you commented on both PVC and Catch Cans that last statement is not factual.
8915GT
Anyone replace their PCV valve or removed it? If so how do you get it out? There is a locking collar over it that will not allow you just to twist it out. TIA
Japeatr
DFW
'24 Mustang DH; '13 F-150; '20 Exped; '05 CobaltSS
FWIW, the owners manual suggests using catch cans when tracking the car.
Track Use - Track Use - Dark Horse
Catch Can
If you plan to track your vehicle and it did not come with an oil catch can, we recommend that you purchase the catch can kit though your authorized dealer or Ford Performance Parts Catalog.
Installation instructions are included with the catch can.
The catch can has a self-draining feature and does not require any maintenance."
Catch Can
That is the can that shall not be found … well at least was unobtainable at time of publication.
