Oil catch can YES or NO?
REV745DH24
So you mentioned that high detergent fuel could prevent the carbonizing the valves? So which brand name of gas actually uses high detergent fuel to prevent the problem? You left that critical info out. Why?
BrianJ77
That was a link to another gentleman that is a former Ford Master Tech and now runs his own shop fixing Ford vehicles in the Chicago area. Best place to look for high detergent fuel is to use Top Tier Gas. Here's a link of all of them: https://www.toptiergas.com/gasoline-brands/
LethalPerformance
Fl
LethalPerformance
Fl
For anyone that doubts whether a catch can is needed or if it works or not.
DCS
Ocala, FL
Would installing an oil catch can affect the Ford warranty in any way?
JAL
Gatineau Hills, QC
2019 Mustang GT
So I have a Gen 3 V-8, drawing 15 ml / 1 Tbs of oil every 1250 miles, 2011 kms. If the car were a DD, putting down 10K mi / 16K km a year, that measures out to as much as 1/2 cup, 236 ml a year. I prefer to keep all that out of the intake system.
I was drawing the same amount (1 tbsp) for every hour of track time (mostly 2nd and 3rd gears >5000 rpm) on a 10k-20k miles Gen 3.
I'm getting a passenger side UPR can for my 2024 for sure.
Not exactly sure, slight grey area. They actually ‘recommend’ one in the owners manual, however the recommendation is in the ‘track use’ section.
Ford has been selling their own branded catch cans. I did some searching this AM. It does not look like their catalog has caught up for the S650. There are aftermarket solutions though.
Warranty concerns come up from time-to-time. Ford would need to prove the part was directly involved in damage to the engine, emissions, etc.
As Ford had been selling them, my opinion is no, it will not void the warranty. However, it does need to be maintained (periodically inspection and emptied) with the rest of the car.
If you DD the car, it would be a good idea to check every few months or thousands of mi/km. If you use your car for weekends and Holidays, possibly as little as once a year, during the oil change. If you race, I'd check it much more frequently (see post #59 above).
The amount of oil captured should be pretty consistent, so you'll eventually find a rhythm. If you discover a dramatic change in the amount of oil captured, or you see a fluid (water/oil mix, something weird) that shouldn't be there, that's a tell you need to investigate further.
If the can is a warranty concern, but you want to use one, simply remove it before taking the car into Ford. The device can be installed or removed in moments.
BrianJ77
I have a UPR catch can on my S650. If it has to go in for any warranty work I will just take it off and put the factory tube back on. Then there's no questions.
cosmo73
Berks County, PA
24 GT, 20 A5
Why would anyone want 2-3-4 ounces or more of used oil spraying back into your intake? For such a simple modification & relatively low cost it is a no-brainer for me.
