OBDII Module for S650?
DCS
Ocala, FL
I have read a little about the OBDII Port on most if not all modern cars. I have also read that there is software called FORSCAN that is specifically designed for Ford and a few other manufacturers to provide similar information. However, it also requires a physical adapter but it does not appear to be ODBII based, but USB.
What is recommended for the S650?
For the moment, you can discount FORSCAN; they currently cannot support 2024MY Fords.
https://forscan.org/home.html
"Ford, Lincoln, Mercury models of 1996 - 2023MY (some models of 1994-1995MY are also supported). Attention: Some 2023MY Ford models may not be indentified (we work on it). FORScan may support limited set of functions and configuration parameters for brand new 2021-2023MY models (we work on it). 2024MY Ford and Lincoln models are not supported!"
  • Like
Reactions: DCS
DCS
DCS
Ocala, FL
Crap.
Dave2013M3
El Segundo,Ca
Forscan is Russian. I believe the sanctions on Russia is impeding Russia from getting access to 2024 vehicles
DCS
DCS
Ocala, FL
What is a good fallback OBDII module and software?
this is not true. on 1/2/2024, they released an update that added compatibility for the 2024 Mustang, among other new vehicles
Dave2013M3
El Segundo,Ca
I read that on another forum. Sorry. I just went over to the sight and updated my Forscan. However I didn't see when the update supporting the 2024 Mustang.
Dave2013M3
El Segundo,Ca
I just read there is still no support for the 2024 Mustangs. Where did you see that the update supported it?
i used it today on mine
https://forscan.org/download.html
Double-checking myself, I found the release notes page for the 2024 download.
If the software supports MY24s, great. If a new customer contemplating a purchase of any scanner device or software, it's something I'd want to study further.
2.3.58 release, 2024-01-02 (download)
+ Vehicle database update
+ New configuration parameters for different modules and models
+ Configuration and Programming function PCM Module Configuration for Kuga Mk1 DW10C
+ Missing diesel PCM service functions for:
  • Kuga 1.5 TDCi 2020+ model year
  • Transit /Custom (EU) 2.0 TDCi 2019 model year
    + Service functions PCM/DCU "Reset Oxidation Catalyst Adaptation", "Reset SCR adaptations after Reductant Injector repair/replacement with pressure line emptied", "Reset SCR adaptations after Reductant Injector repair/replacement without pressure line emptied", "Reset SCR adaptations after Reductant Supply Pump repair/replacement","Reset SCR adaptations after Reductant Tank repair/replacement", "Reset SCR adaptations after Reductant Line repair/replacement" for the following diesel models with SCR/DCU system:
  • Galaxy/S-Max 2.0 TDCi StgVI 2015 model year
  • Everest U375 2.0 TDCi 2018-2022 model years
  • Everest U704 2.0 TDCi 2023 model year
  • Mondeo 2.0 TDCi StgVI 2015 model year
  • Ranger P375 2.0 TDCi 2018-2022 model years
  • Ranger P703 2.0 TDCi 2023 model year
    + Service function TCM "Learn Clutch Touch Point" for:
  • Fiesta/Fusion/Ikon 1.4 Duratec/TDCi (ASM transmission) 2002-2006 model years
    + Service function CCM "Calibrate Cruise Control Sensors" for:
  • Transit V363 (North America) 2020-2023 model years
    + Service function VDM "Ride Height Calibration" for the following models with pneumatic suspension:
  • Expedition 2018-2023 model year
  • Mustang 2021-2023 model year
    + Service functions VDM "VIN Learn", "Suspension Temperature Calibration" for the following models with pneumatic suspension:
    + Sub-function "Show distributed PATS scheme" of the "PATS Programming" function for some models
    - bug: PATS Programming -> Module initialization false initialization error message on some models even if the function has completed successfully
    - bug: disappeared service function RFA "Remote Keyless Entry and Start Programming" for many Mazda models
    - bug: incorrect work of some PATS programming functions (bug appeared in 2.3.57)
    - bug: incorrect work of RCM "Module reset/configuration" function for Focus Mk3
    - bug: incorrect work of some PCM service functions on SID-210 ECU (bug appeared in 2.3.57)
LCDRChemEng
Yulee, FL
2024 BE DH Premium A10
For clarification, the OBDII port is still there under the dash. FORSCAN (and other such apps) is installed on a tablet or laptop. The required adapter uses a USB connector on one end and a OBDII connector on the other. Search the FORSCAN website for the recommended adapter. This allow the tablet running FORSCAN to tap into the vehicle's systems.
DCS
DCS
Ocala, FL
I understand the process and the components. I was curious as to which module (brand) and software is recommended. I am not too crazy about using some Russian developed software on my car's electronics.
Would say good luck, the Russians have been involved with safe software development and design since the days of Tetris.
DCS
DCS
Ocala, FL
There are alternatives. I'm simply asking what people are using (software & OBDII to USB link) on their Mustangs.
