- Joined
- Mar 11, 2025
- Threads
- 33
- Messages
- 2,597
- Reaction score
- 3,016
- Location
- New Zealand
- Vehicle(s)
- 2025 Mustang GT
You haven't comprehended what I wrote.--> Depends on the tires and surface conditions. On some tires or surfaces, the slip angle is dramatic enough that the car is visibly sliding. Thats why if you watch old cars race on bias ply tires, they are all sliding through the corners. Its not as simple as "any oversteer is bad".
--> The tires will absolutely take further accelerator input. If you keep giving the rear more power, you will keep propelling yourself forward. That's just how it works. If you're countersteering correctly, then you should absolutely give the car a little bit of throttle, but not an excessive amount.
--> Squaring the corner is taking the shortest line to optimize the time spent accelerating. You're essentially making the track, or section of road before and after the corner, as straight as possible. Trail braking and/or slow-in fast-out are simply methods to achieve the end goal of squaring the corner, or making the track as straight as possible.
Yaw or rotation is prior to actual loss of traction or sliding. It's an increase in slip angle at the rear tyres, it's not loss of traction.
I've driven a lot on cross ply tyres, they slide even with the low power outputs of 50's and 60's cars. It's not a good comparison. I also never said any oversteer is bad, it works well off road and is fun on road
But this drifting style of driving is not the fastest way around a track, or road.
You can accelerate when your car starts to slide on your way to work, I'll pass. It's the way to Youtube stardom.
Your 3rd paragraph is exactly what I said.
