Has anyone noticed hood lift?
nle_bonqueque
orlando
2024 Mustang Ecoboost & 2024 Mustang Darkhorse
I have a 2024 ecoboost and darkhorse, and on both I’ve noticed at 60mph+ the hood will move up and down or maybe buckle a bit. I went to Sebring last week with the DH and I had thought the latch didn’t shut all the way and had to go back to pit road to check. And when I did it was fine. Wondering if yall have noticed the same thing. Thanks
I have a little movement at speed. I stopped once to check, and all was well, then I noticed the hood released warning light comes on when it's off the main catch.
Fruitstang
2024 Mustang GT Convertible
This has been happening with my Gen6 and the Gen7 as well.
Starts typically at higher speeds of around 90 in most cases that have been reported in Germany.
Adjusting the rubber bumpers to get more tension on the front corners of the hood helped a tiny little bit.
At lower speed it might solve the problem completely.
npole
Italy
Mustang Dark Horse 2024
Same here, it's ("visual") issue on both S550 and now S650, adjusting the bumpers will improve, but you'll always end with a fluffy bonnet, because it's very light. It's even worse if you drive behind a big vehicle (a truck or such). But as said, it's just an annoying effect, the thing won't go anywhere.
Not a bit for me. Guess I'm lucky.
Twizzty
Central Florida
2027 Corvette Z51 and others
If you think Sebring was bad just wait until you try it at Daytona!
At 160 mph I thought my S550 hood was going to "leave the chat" as my kids would say. It never did though but the amount it moved was crazy and it sounds like the DH is the same.
Old School1
Illinois and Michigan
2024 GT Premium Convt, DMG, PP, AE,6-speed, 2022 F150 Black Appearance, 3.5 TT
I saw it and was immediately concerned with the amount of movement. 70MPH and on windy days. It is secure but the adjustments help.
Lakersfreak
Los Angeles
24 Mustang GT
I had the same problem. Tighten the hood bumps and it will go away.
Some movement appears to be expected, but adjusting the stops has helped mind calm a little.
I noticed on the ride home from the stealership on TX130. The speed ‘limit’ is 85mph but 90 is the slow traffic in the right lane, 100-105 is the passing lane - I’ll call it “cusotmary” speed. I was ok until I got behind someone, in unclean air, at speed. Then it moved around quite a bit. I checked on here and several folks had the same report and same reported suggestion ; adjust the hood stoppers (whatever they’re called)
Aggie1999
S650 PREM GT
I love those roads around Austin!
freekshow02
Idaho
87 Mustang GT, 2024 Dark Horse
I noticed it just little bit and had the same thought going down the highway at 85 yesterday. Everything checked out when I got home though.
