Has anyone here done a DIY gear swap (10R80)?
Crow
Midwest
2024 Mustang GT non-pp 10R80, 2018 Audi TT-RS, 2017 Audi A3 Quattro
I am debating whether to swap gears on my 3.15 10R80 car. The plan would be to buy the whole pumpkin from Ford Performance and install it myself, or possibly find a shop to build a Wavetrac or Torsen for me. I've swapped a diff out before but I'm no expert and until now I've mostly owned German cars. I'm pretty comfortable with the idea of swapping the whole pumpkin, but rebuilding the diff isn't something I've done before. That said, I don't know of any shops in my area that would do it.
Has anyone here gone the DIY route on a gear swap on the 10R80? If so (or even if not) I have a few questions before taking this on.
1. Do I need to change the pinion flange if I buy the whole pumpkin from Ford? It reads to me like it is only required for the 15-17, but I wasn't sure here.
2. Does anyone have a link to the Forscan settings necessary to set the gear ratio so the transmission shift points, etc are correct? Or is a tune necessary here?
3. For anyone who has driven the 3.15 and 3.55, is it worth swapping to 3.55, or is going straight to forced induction the better path? My concern here is melting the cats with a supercharger - no cats = my wife probably won't ride in the car, and I can't say I care for the smell either.
Any advice or experiences would be appreciated!
ZXMustang
tooner
Yes I own two S650s with each gear and the 3.55 gears are superior by far. Unless you are going to do a blower, then you might want the taller gear to help with 1st/2nd gear. But for NA cars, the 3.55s are magic compared to the 3.15s.
Rebuilding diffs is not hard, but does need engineers blue, dial gauge, and having been taught by someone who knows.
Neggytive
Normally I'd say look on car-part.com and see what was out there for a whole used 3.55 differential, but there are not a lot of them listed and they seem to want stupid money for them.
Dropping a whole pumpkin in there is probably about the same price as getting a set of gears, the shim/install kit, and finding someone that knows what they are doing to set it up.
It is generally accepted the automatics do not NEED the 3.55 because the first 6 gears move so fast and the ratios work to keep the car moving
A stick does not have the advantage of the intermediate gears, and somewhere on this forum I posted a reply showing how the final gear ratios work out with the various transmission and rear end options, you can do the math if you know the transmission ratios for each gear and the rear end ratio
Now the question is what are you trying to accomplish and what are you willing to give up to get it?
You can also use any one of a dozen online calculators and work backwards from 70 MPH, knowing the tire diameter, rear ratio and say the 10th gear ratio which IIRC is something like .636 to 1 and figure out if you can live with it, and you can approximate it probably by driving the car in 7th or 8th gear with the 3.15's in it, again just calculate out the rpm using the tire diamater ( easily found online) the gear ratio ( 3.15. 3.55, or even 3.73) and the transmission ratio and see where the RPM's come out
There is more to this than what I am willing to get into, such as having the right gear to keep the engine spinning where it makes the most power, if the engine can't spin the gears for lack of power or you are way out of the power band you are just wasting money.
Gear Ratio
1st 4.696
2nd 2.985
3rd 2.146
4th 1.769
5th 1.520
6th 1.275
7th 1.000
8th 0.854
9th 0.689
10th 0.636
A 255-40R19 tire has a diameter of 27"
So using this lets try the math
S650 Mustang Has anyone here done a DIY gear swap (10R80)? 1782783471789-9t
RPM=70 * (3.15*.636)*336/27
RPM= (70*2.0034*336)/27
RPM= 47,120/27
3.15 gears RPM to do 70 is 1745 rpm's
Now do 3.55 10th gear 70 MPH
57845/27 now you are at 1966 RPM's doing 70
In 8th gear, 3.55, almost 2900 rpm @70
Now if you want to go deep, say 3.73 and I think there is a ford center section for that, remember 2018 to current fits, just got to change the flange....
RPM= (70*(3.73*.636)*336)/27 =2066 RPM's cruising at 70 with 3.73's in 10th
OK so you want to do 120, and never go into an OD gear, the math gets simple
Lets do 3.55's
(120*3.55*366)/27 , 5300 RPM's and that is a sweet spot for that engine
3.73's
(120*3.73*366)/27 comes out to 6067 RPM's in 10th
in 8th
(120*(3.73*.854)*336)/27
120*3.18*336/27
128473/27 = 4756 rpms, but you are in an OD and the engine is not going to be thrilled trying to make speed without the benefit of torque multiplication.
But now that you know how it works, and if you look at a stock dyno curve and figure out where the sweet spot is, and shift right above it so the power drops back into the sweet spot, you can figure out if you can get the benefit of a lower gear by manually shifting and keeping the engine in the sweet spot or of you want to drop 1200+ install labor and a flange kit to swap the center section.
If you do swap out the center to a 3..55 or 3.73 ( go big or go home!) look to see what hardware is single use/torque to yeild and make sure you have it on hand when you start.
And the Forscan stuff isn't hard as far as telling the modules the correct value for the speedo to read right, but you might want to force the transmission into relearn mode to adjust for the new gears.
It requires going in and clearing some data with a bi-directional scanner then driving in a specific way to get the transmission to start learning again
tktrain
Evansville, IN
Nice write up, Neggytive. I have a '25 DHP with 3.55s in the back with a 10R80. These gears are nice in N/A, but when I put a Whipple on at just over 500 miles, wow, what a great setup. I went with an oversized intercooler, twin cooling fans, a Bosch high flow intercooler coolant pump. I also put in billet oil pump gears and timing sprockets for insurance, a lethal double H pipe with high flow resonators, a vapor catch can system. I can spin the back tires into 4th gear. If you're on a sticky, prepped 1/4 track, it's thrilling. 769 HP at the rear wheels is stunning.
Neggytive
That 3.55 with the low first gear of the 10r80 with that much HP/Torque must be a real neck snapper
Are you running catch cans on both sides or just the "dirty" side?
Assuming you don't have a Torsen differential which I have no experience with I would purchase the entire already built , and not been messed with pumpkin, end to end. I've replaced/installed a couple of 8.8 Ford gear sets on older cars and it's more of an art than a science. If you want to go that route, check with a local Mustang or other muscle car group and get recommendations for specific mechanics who have been doing this a long time and have an excellent reputation for noise free installs. Also have the mechanic order the parts because brands do count and he will order what he knows has a proven record for installs.
That being said.
If you cannot locate an experienced mechanic, I would go for the entire unit brand new or a takeoff from a brand new car.
Best wishes.
tktrain
Evansville, IN
Just on the "dirty" side. So far I only have about 500 miles added since the Whipple install.
