thePill
Camaro5's Most Wanted
Pittsburgh
S550
A GT350 will be available upon release due to GT3 and GT4 requirements. The S550’s GT350 technically has a 3 year grace period but I don’t expect Ford will miss the opportunity to market in Motorsport. 😉
cmxPPL219
Toronto, Canada
2019 Mustang GT PP2
To me, the tips on the mule look more like the Mach 1 with the "rolled" tips
Spot on are my sentiments. GT500 have less of that rolled tip look as you mentioned, making the ID measurement a bit bigger.
cmxPPL219
Toronto, Canada
2019 Mustang GT PP2
And a wheel comparison. This white GT convertible is a UK GT......we had the option of the Performance Pack wheels in silver.
To me, the design looks identical, but the mule wheels appear larger. The definitely fill the arches better, so they might have a revised offset and the suspension is definitely lower.
My initial thoughts as well. I actually had these same wheels on my previous 2017 Black GTPP (very few North American 15-17 GT Performance Pack cars got these hyper silver finish from the factory; more were in Europe obviously)
Also, it could be distortion of the mule image, but if you look super close, near the hub and wheel lug nut area, the spokes appear to have a like a mirrored-turn effect, suggesting a slightly different design. This could be image distortion though. We'll see soon!
Mike Pfeifer
Wesley Chapel, FL
2019 Mustang GT
I think you are right about the center of those spokes, they are different. Each pair of two is turned toward each other.
cmxPPL219
Toronto, Canada
2019 Mustang GT PP2
The look like they could be, it's too bad the image is a little distorted. Hopefully we find out more details soon.
Twin Turbo
Super Moderator
Moderator
England
Mustang '05 GT
thePill
Pittsburgh
S550
It will look a lot like these photoshops. Keep the current hood/upper grill design in mind because this photoshop retains the old S550 style. I believe the new Mustang’s hood line will either conceal the top of the grill completely or, only show very little of the top of the grill.
The rear will also host all the new angles and edges that Ford’s remaining car fleet uses as well. I expect all the rounded lines on the sides of the S550 will also be more edgy. I don’t think the smooth sides of the 2022 will work with the more aggressive angles on the front fascia.
I am very, very eager to see if the greenhouse has changed at all. Maybe some slight variations from the B-pillar back, a more tailored or tapered C-pillar to make the hips appear to flare more? I know one thing… a larger grill area tells me the Mustang wants more air and Ford probably has plans to feed it something extremely powerful.
S650 Mustang GT500 Mustang S650 Mule! 📸 FE94E94B-DF95-422D-818F-A2FAAAEF9A53
S650 Mustang GT500 Mustang S650 Mule! 📸 91941453-BB51-4BE1-904F-BC4810B4B1C4
S650 Mustang GT500 Mustang S650 Mule! 📸 544D118D-9CB2-4146-842D-CAC0CB4426E5
S650 Mustang GT500 Mustang S650 Mule! 📸 76772E7D-6DBF-40DD-9F44-3E7161FB06A7
HoosierDaddy
Winchestertonfieldville (ok, Scottsdale), AZ
2016 GT Premium PP
Silver versions of those wheels have been available in Rest of the World markets since 2015.
US also, at least for MY '16. When I ordered mine, option 64F got you nickel painted wheels with the Performance Package. The only indication on the window sticker was an extra ~$200 added to the MSRP for the Performance Package and mention of the nickel wheels in the PP description.
S650 Mustang GT500 Mustang S650 Mule! 📸 1650832440750
Stevefreestyle
Blue Blood
Wollongong NSW Australlia
Really strange that Ford is adding camo on S550 body prototypes. It's like they want people to register that they are testing something.
Instead of "we cant show you this", its "Look at me over here !"
okfoz
Doghouse
2016 Roush Stage 3
If the
2015-2016 S550 is Version 1
Then
2018-2023 S550 is Verson 2
Why does this strike me as more of a 2024 Version 3 than an S560 complete overhaul?
John
Ace
www.modernmusclecars.de
2023 C8 Stingray
Since they already had a S550 in camo on the roads, I doubt even this frontend here is from the S650. It's just a camod Mach 1 where they removed the frontsplitter.
S650 Mustang GT500 Mustang S650 Mule! 📸 1650974517694
S650 Mustang GT500 Mustang S650 Mule! 📸 1650974525406
DeluxeStang
Utah
Explorer
Idk according to Ford authority's sources, this mule was using the finalized s650 gt front end.
shogun32
Northern VA
2019 GT+PP, SS+1LE, 2020 F150
I don't know why you keep yanking on this old saw. The GT and GT350 have the grills heavily blocked. You can't usefully feed a radiator complex very much air - it's counter productive. The size of the grill is a design element, nothing more.
If you look at eg. the beaver teeth on a BMW, most of it's actually solid panel - ie blocks all air.
I don't doubt they'll Gundam/chisel the shapes that were compound/organic in the current generation.
and? The S650 wouldn't just recycle the Mach1 face? with perhaps some obligatory tweaks so it doesn't instantly piss off all those M1 buyers who thought they were getting something special/unique?
I'd like to see a bumper that had no top cross member. ie. the hood finished the top boundary of the catfish
  • Like
Reactions: JWS
MustangMac67
Chicago
Ford F250
Yes
  • Like
Reactions: Cap
thePill
Pittsburgh
S550
I don't know why you keep yanking on this old saw. The GT and GT350 have the grills heavily blocked. You can't usefully feed a radiator complex very much air - it's counter productive. The size of the grill…
🤣 no, no it’s not… the S650 is being optimized for Motorsport… 🙄
