Changing tire size using FORScan
I installed my new track tires today and updated the tire size using Forscan. There is an option to update the tire size in the BCM by entering the new circumference in mm without having to change the address values, which is what I did. The stock tires were 275/40/19 and my track tires are 295/30/19 (6.1% shorter). After changing the tire size in the BCM, I drove on the interstate for 120 miles. The speedometer was dead on with my gps, and the car did not throw any codes, drove great and cruise control worked without issues. I did not reset or relearn the PCM or TCM.
Thanks for sharing!
gbadger
FL
Did you need the computer version or could you use the app on an iphone?
krisk
I used the computer version, so I don't know if it would work with the iPhone app.
Cobrakit
Southern Maryland
2019 Mustang GT PREMIUM PP1
I installed my new track tires today and updated the tire size using Forscan. There is an option to update the tire size in the BCM by entering the new circumference in mm without having to change the address values.
So this is what is referred to as the Easy Mode? Vice changing characters in the BCM As Built.
I never attempted to use forscan. Weirdly my speedo is still within 1 mph to the GPS at highway speed after the wheel change. According to the math it should be off by more than that. 🤷‍♂️
Thuggs
Tasmania
2024•5 GT
I was back home and checked where the on screen adjustment was and it is in the driver settings very easy to adjust
Thuggs
Tasmania
2024•5 GT
In what country or trim?
Australia I don’t know the trim it’s a 2024.5 GT manual 5.0 we only get add ons of recaro seats magnaride we don’t get base models ours come with electric mirrors 19 inch wheels and full dash screen not a 2 piece
gbadger
FL
Crazy you can do it in Australia but not in the US. That’s awesome though.
A.alansari
Qatar
Mustang GT 2024 PP
can you share your as built data i want to compare it to my car you can grab it from motorcraft/asbuilt
Is it possible the factory TPS syncs with the cars computer and adjust the speedo accordingly? I'm still trying to figure how and why my Speedo and GPS speed never changed when I swapped out my premium wheels and tires (255/40-19) with a set of take off PP wheels and tires (275/40-19 rear).
