Assistance Needed: Enabling Remote Rev Feature in Mustang Dark Horse Using FORScan
gtr9uae
Z
Mustang dark horse
I recently received my Mustang Dark Horse from the dealer, but I was surprised to find that the remote rev feature does not work, even though the car has an active exhaust system. I have tried all methods to activate it with the car key and watched YouTube tutorials. My conclusion is that the remote rev feature might not be working because the dealer may have disabled the feature in the car's computer. Can I enable the feature using the FORScan program or verify if the feature is indeed activated and not disabled? Please provide an explanation with pictures, as this is my first time using the FORScan program and I have no experience with it.
gtr9uae
Z
Mustang dark horse
Yes, My car is auto. I believe the issue might be due to regulations. Can I enable it using FORScan?
Billycar11
probably
try this
pcm tab
line 253
what country you in that they disable it on you?
Donj02
Missouri
Make sure you wait long enough after cold start. It takes 15-30 seconds after cold/warm start before it will work. So wait until the tone changes after initial startup then do fob sequence. I thought mine was broke too until I found this out.
YamenGT650
Dubai, UAE
Mustang GT 2024 PP
Mine is in the UAE as well, and i tried remote Rev but failed… i guess the dealer removed it
Most likely, the manufacturer removed it, knowing which market it was going to.
gtr9uae
Z
Mustang dark horse
From where can i see on forscan if future is available on my car or not could you show me by taking screenshots
Slothman
2024 Ecoboost Vapor Blue Nite Pony
Has anyone been successful enabling remote rev on a car with it disabled?
Dark Sprite
UAE
Did you manage to get it enabled? If so, did the dealer activate it for you?
YamenGT650
Dubai, UAE
Mustang GT 2024 PP
Nop, i asked them about it, they said it's intentionally deactivated for Middle East version. But it can be done through FORscan, but i don't want to void my warranty.
Dark Sprite
UAE
I don’t see the risk of voiding the warranty by simply removing such restriction as the car functions with it perfectly fine in other countries. I don’t think it’s illegal to have a remote rev function, it’s illegal to exceed certain dB limits but the light rev noise it makes is certainly less than when you put your foot down...
YamenGT650
Dubai, UAE
Mustang GT 2024 PP
I didn't mean voiding warranty by using remote rev, i meant by changing the car default software settings using Forscan, they can say you messed with the car.
Dark Sprite
UAE
I didn’t say voiding it by using remote rev, I was talking about removing the limitation in the software that has switched off remote rev - but again, how would that void warranty if it’s a standard feature on the car that’s just been disabled?
Fruitstang
2024 Mustang GT Convertible
PCM
7E0-162-04: "x2xx" "xxxx" "xx--"
This worked on my German GT, where it's turned off by default.
