Amber DRL via Forscan (and FDRS) - YES!
Grant4514b
Louisville Ky
2017 GT, 2020 GT500
DO THIS AT YOUR OWN RISK. YOU ARE RESPONSIBLE FOR ANYTHING YOU SCREW UP DURING THIS PROCESS IF YOU DECIDE TO TRY IT. This is confirmed working on 2 vehicles as of today. Huge thanks to @roket - without his help this would not have happened. FDRS and Forscan in required to make this work. There are plenty of threads that will get you going with those programs so just do a search if you’re not familiar with them. You will also need to obtain a GTD vin number. I will not publicly share someone’s vin.
Procedure:
Leave USB unplugged from PC
Open FDRS
Manually enter GTD vin
In toolbox, download LDCMB and LDCMA
Plug in J2534 cable to PC and car
Run LDCMB (PMI)
Run LDCMA (PMI)
Is original module installed- yes
Close session
Forscan LDCMA 6F6–05–06 set to 0910
LDCMB 6F7-05-06 set to 0911
Also, those who have 2024 model year job one need to reprogram their HCM with the programming from a 2024 job 2 or later, so you will also need a vin for that. If this is not done, your headlights will never turn off.
Full transparency - I am having an issue where my trunk will no longer open with the dash or bumper buttons, but it now opens with one press of the unlock button on the key fob and 2 presses on the unlock button on the driver door. I have no idea when this started happening but I have spent hours trying to fix it with no success at this point. It could’ve happened during previous trial and error testing or could’ve happened during the above procedure. The other car that has the working DRL does not have any issues.
and yes, this does work on 2024 job 1 vehicles, but you NEED to program the HCM with a 2024 job 2 or later programming. also change the VIN in the HCM afterwards with your own, or any subsequent FDRS sessions on the vehicle will complain about a VIN mismatch
also, quick disclaimer to protect me and Grant:
By doing this change, you hereby understand that you are doing so of your own choice, and you accept the risks associated with the modification. No warranty or guarantee is provided with this tutorial, implied or otherwise. Failure to follow the instructions provided in the tutorial or FDRS may cause problems such as corrupted module programming, permanently damaged modules, and a whole host of other issues. Changing the programming in your LDCMA and LDCMB also basically voids your bumper-to-bumper warranty coverage on those modules. By continuing with this tutorial, you accept these terms and will be holding nobody except yourself accountable for any damages that may be caused by this modification.
ChrisMattice
Albany NY
2017 Ford F150 XLT
Great job everyone! Guess I need to find someone with access to a cable and FDRS now haha
ChrisMattice
Albany NY
2017 Ford F150 XLT
@Magic88 are you in Bennington VT? If so I’m not too far from you. I’ll gladly drive out to meet a fellow forum member haha
some pictures
fablighting
Los Angeles, CA
2024 Ecoboost
Incredible work getting this done. Been following along closely on the other thread these last few weeks and I'm happy to see the hard work paid off.
Is the Mongoose cable confirmed working for the FDRS portion of this mod, and is that the most affordable cable option available for this? I'm assuming the basic OBDLink ForScan cable doesn't cut it with FDRS.
NegativeMultiplier
Ok, who's coughing up GTD vin #'s for all of us? šŸ˜‚šŸ˜‚šŸ˜‚
Do they need to be real ones? You could make some that aren't assigned to a real car using the information available on the NHTSA database.
I will admit something about that feels illegal, so I'm compelling myself to say that those should not ever be used in any official capacity. šŸ˜…
A.alansari
Qatar
Mustang GT 2024 PP
finally that's incredible
so how to revert back to white is it just changing the forscan block number back or you need fdrs?
Magic88
Bennington
No idea about that
Changing the color of lights isn't illegal, it's cool! Haha
Grant4514b
Grant4514b
Louisville Ky
2017 GT, 2020 GT500
Yes the Mongoose is what I used. That cable also works for Forscan if you don’t have OBDLink.
Grant4514b
Grant4514b
Louisville Ky
2017 GT, 2020 GT500
You need FDRS. The change in Forscan has no effect on the color.
