Amber DRL via Forscan (and FDRS) - YES!
Warlords650
tampa,fl
2024 vapor blue GT
This might be a bit off topic but has anyone figured out how to do the steps in FDRS to program the IPC and APIM in order to get the GTD Gauges?
That would likely require programming them with GTD version software much like the LDCMs in this mod... which may or may not brick the car...
robotninjasrule
24 GT
Please excuse my ignorance, does the procedure on the HCM move a job1 car to a job2 ?Follow on question is there a definitive way to tell job 1 from 2 ? Mine has auto start stop that has never worked and was built march or April.
Awesome job guys! Sick mod going to do next time I get an fdrs licence !
Modesto, CA
yes it does. Enjoy
robotninjasrule
24 GT
I would like to explore this option, I noticed the GTD had a different mode with a large dial tach similar to the calm screen but better!
robotninjasrule
24 GT
I would like to thank Grant4514b and everyone one else who helped, i successfully swapped over to the amber DRL's!
I spoke to the saudi guy on whatsapp he essentially said you gotta flash the apim and ipc with the GTD versions on FDRS
Not sure if something was lost in translation here or some voodoo magic. I tried the same method to change to amber DRL on the APIM to change to the GTD Clusters using the GTD PMI's and it will not work. I get a Vin mismatch error and it just endlessly loops during software install. I am able to download the new software for the apim from the GTD which has a "part number of RU5T-14G682-AX. Unless there is a way to skip the Vin check i don't see this happening.
BTW the new prices for FDRS suck! just paid 170CAD to change my DRL color lol
A4techpl
NY
GT S650 Convertible
What is difference in IPC beside the GTD animation - car ?
GrabThatBlue
Between Canada and Europe
If you do the GTD changes in Forscan you will only have the GTD screen on the middle screen.
In FDRS you can program the GTD animations on your main screen.
A4techpl
NY
GT S650 Convertible
Apim is not an issue. I have already AX and even newer EL version.
My question is what else beside GTD car logo give us ? I hoped GTD has new Theme for the IPC but seems all the same :)
GrabThatBlue
I don't know what you mean exactly but the GTD has its own theme.
A4techpl
NY
GT S650 Convertible
I can not find on YouTube or anywhere else how does IPC Cluster looks like on GTD - if there is own Theme.
