Sunglass holder in overhead console - issues
Killshot58
Yorktown, Va.
2024 Mustang Premium GT, Vapor Blue, Nite Pony Pkg
Has anyone else had issues with the sunglass holder? Mine has broken 2X so far. It happened so fast the 2nd time I'm not quite sure how it actually broke. I reordered the part (overhead console) the first time. $400. It broke again after about 2 weeks. Very frustrating ! Not sure about dishing out another $400. Can this covered under the warranty ?
Bear376
Stillwater, OK
If it broke while the warranty is in place, then they should repair/replace it. This will be a good test of your dealership service. A good dealer will replace it with few questions. A bad dealership will try to get out of it by claiming you abused it.
Bikeman315
Myrtle Beach, SC
2019 Mustang GT/CS
I do understand how you could shell out $400 for a part that will definitely be covered under warranty. I’d be asking for a refund, especially after the part you bought broke (assuming you installed it wrong causing the second break).
I use mine regularly with NPs. Like the other members said; minus abuse; it should be a warranty issue.
D/\rK•650
2025 Mustang DarkHorse
Definitely go through the warranty if you have the coverage. Maybe also ask to be reimbursed for that 400 dollars, it's not peanuts. If it were a 5 dollar part then forget about it. That is a weird thing to break in my opinion. Good luck buddy :fingerscrossed:
37.5726028 / -85.1551411
Are your sunglasses to big for the holder? My Oakley's wont fit so I've turned to the visor clips.
135Hoser
2024 Dorkhorse, 2024 CR-V
Mine rattles with nothing in it. apparently they have to order the whole headliner or some shit and its on national backorder so ???? when it will arrive.
Frogdog1
Dixie
Farley is cheap except when it comes to MSRP.
Doug Watson
Mine broke after I left it down and hit it when I got in the car. Replased under warranty. I's a crappy place for it like it better when it was in the lower right drivers area.
