Steeda sells themWhere did you pick up these rubber coil covers? Thanks
Ive had the same issue but it does have a little clunk when braking but only when it comes for a full stopSorry to revive this old thread but I just installed the same springs and ran across this same issue on mine.
I didn't notice it at first but I'm getting a clunking noise at low speed rough terrain conditions, so went back to check everything and noticed how the spring sits.
Have you had any noises/issues since your install?
Get the isolators it will stop.Ive had the same issue but it does have a little clunk when braking but only when it comes for a full stop
That is how mine started to do the clunk. After I'd come to a stop , then a clunking in the rear. Then it started the clunk when slowing down like at 15 or 20mph. If you haven't maybe take your car in if you think something is wrong. Apologies if this isn't your concern i just noticed your post. Edit: the clunk I'm referring to was in the driveline on mine.Ive had the same issue but it does have a little clunk when braking but only when it comes for a full stop
Iāve heard mine clunking when slowing down. What was it? Iāve looked at the forums and if I recall itās something that needs to be greased properly? I may take mine in to get it checked just hate taking it to the dealer and leaving it.That is how mine started to do the clunk. After I'd come to a stop , then a clunking in the rear. Then it started the clunk when slowing down like at 15 or 20mph. If you haven't maybe take your car in if you think something is wrong. Apologies if this isn't your concern i just noticed your post. Edit: the clunk I'm referring to was in the driveline on mine.
It was the tinq ring, and it needed to be greased along with something else i think with the shaft on the driveline. I think I posted pic my dealership invoice on here, if I find it I'll repost. If your experiencing this definitely take it in. Honestly Ford needs to make a service bulletin for this.Iāve heard mine clunking when slowing down. What was it? Iāve looked at the forums and if I recall itās something that needs to be greased properly? I may take mine in to get it checked just hate taking it to the dealer and leaving it.
Yes please if you can send it to me. Iāll have them take a look. Iāve had it for a while but just keep pushing it aside.It was the tinq ring, and it needed to be greased along with something else i think with the shaft on the driveline. I think I posted pic my dealership invoice on here, if I find it I'll repost. If your experiencing this definitely take it in. Honestly Ford needs to make a service bulletin for this.
Here is the thread about this. I'm gonna look for the service invoice because I can't find where I may have posted it on here.Yes please if you can send it to me. Iāll have them take a look. Iāve had it for a while but just keep pushing it aside.
