Power Washer Recommendation
Flash
None
For those home retailers which power washer do you have or would recommend and why?
GooberDH
2024 Mustang Dark Horse
All depends how much you want to spend. I have a gas Generac that's been severely neglected I've had for like 8 years and it fires up every time, works great. I went down the rabbit hole for electric units because I'm sick of the noise, shutting down and restarting between foaming and rinsing.
Basically you ignore PSI and want at least 2 GPM flow rate. Days of reading and watching reviews, sounds like a Kranzle K1322TS is the best you can get electric wise for car detailing without absolutely needing dedicated 20A outlets, they say it can spike past 15A draw with foam cannons but a wider orifice on the cannon should help with that. I plan on getting one at some point. Kranzles are over engineered and built to last with proper maintenance which they design to be easy.
MNPony
Minnesota
I got the Ryobi 1200 PSI 1.8 GPM Cold Water Automotive High Flow Electric Pressure Washer Kit last year and have been very happy with it. It's routinely rated as one of the top budget friendly power washers. Typically on sale for $150 at local retailers.
exm
Long Island, NY
I have the same one, it's perfect for the car and small jobs around the house. It's currently $169 at HD.
Jdio
2024 gt pp 2018 gt350 2003 cobra
kranzle or active 3.0
Flash
None
Can you hook up a foam cannon to it?
Dark Sprite
UAE
I’ve used a Karcher K4 for the last 8 years, has been pretty good and wasn’t expensive, not amazing but fine for a weekly wash. The lance recently gave up so I replaced it with an MTM Hydro SGS35 stubby trigger and PF22 foam lance, absolutely brilliant and much easier to manipulate than the long Karcher spray gun with not more tangling - wish I’d gotten it years sooner.
exm
Long Island, NY
TMR
NC
'26 Mustang GT Vert, '21 F150 KR, '25 X5, '25 X3M50
After burning through an expensive gas PW, I picked up a Craftsman 1900psi electric a couple years ago. I believe it was under $150 at the time.
Not too strong for the paint when washing cars. Drives the foam cannon. Works well on patio furniture and spot cleaning. Not strong enough for big sidewalk jobs.
