Oil level after delivery of new car?
I don't put enough miles on as the blend has worked fine. I have used Ford oil since 1969.
REV745DH24
For all you guys regarding oil level check on your Dark Horses or all new Mustangs! According to the manual says this!
Hey, on the oil situation! When I had checked the oil it was really low like 3/16th of an inch just above the bottom line! As I was puzzled and got out the manual book and did some reading and was shocked to see the “Note:” section that says “If the oil level is between the maximum and minimum marks, the oil level is acceptable. Do not add oil.” That was wholly different instructions from the past vehicle instructions that I’ve seen before!!! In the past you could see and make judgement of the oil addition but this is a bit different! So be careful on how much oil you could put in! Take care!
That's how I've treated every single car I've owned since 1983.
37.5726028 / -85.1551411
The only time you need to be right at the max fill mark is if you are doing a lot of twisties, quick deceleration, quick acceleration, etc., as if in road racing, so the oil pump is always sucking oil and not air. :thumbsup:
