Oil filter for 2025 GT Mustang
hoopstir1
Limerick Pa
tocoma ,harley davidson, mercedes benz,2025 GT Ford Mustang
Hello All
Has any one use ford performance plus oil filter or the regular motor craft oil filter ready to change the oil filter & oil soon coming out of storage only have 989 miles on It came in on 11-Sep-2025 I would like to use the best filter out there? thanks in advance.
Alan Applegate
Roswell, NM
Since I do not change my own oil... I leave it up to the dealer personnel. While this may sound an alarm for some, I don't as I read on the repair invoice the exact part numbers they used. In every case it is the premium 'performance' one.
By the way, I don't believe it storing vehicles, especially so when they're just left to rot until spring. When you do, the results can be rather spectacular.
BimmerDriver
RDU, NC
BMW M3 w/3 pedals
I suspect that the only difference between the two is the price.
What came on the car from the factory? Use that.
Edit: I see now that part of your punctuation-free question was what did we use? I used the regular oil filter.
ohioguy
24 GT, 16 Challenger Hellcat, 74 VW Bug, 71 Plymouth
Regular Motorcraft Filter
tktrain
Evansville, IN
My first choice: Mobil One filters, number 2, Motorcraft Filters. Look at the Beta ratings on filters, they can be tricky to understand so I suggest you dig into it. There are some very decent articles out there. Some manufacturers, I believe, are purposely secretive about their Beta numbers. The info is out there. BTW, Champion Laboratories makes about 50-60% of all the filters out there. You'd be amazed.
Those white Ford filters 'flow more' while 'filtering slightly less', but I haven't seen any actual data.
GrabberB
Hello All
[/QUOTE]
_________________________________________________
I use the recommended Motorcraft FL-500-S.
Unless told otherwise, I'll assume you're referring to the Ford Racing High Performance Filter CM-6731-FL820 which is superior to the Motorcraft FL-500-S. The Ford Racing filter gets discussed from time to time. Most wanting to know if it will work/fit. I've never seen anyone answer the "will it fit question" so I will......
Ford Racing High Performance Filter CM-6731-FL820 will not fit 4-Gen. 5.0 Coyote engines found in 7-Gen Mustangs due to diameter - It's to big.
Short of an oil filter relocation it's a no go.
hoopstir1
hoopstir1
Limerick Pa
Has anybody used the K & N oil filter ?
GrabberB
I would not recommend K&N.
EgoBoost
9/11 Never Forget
FL
2025 Black GT MGW Shifted/Roush Blown
…Ford Racing High Performance Filter CM-6731-FL820 will not fit 4-Gen. 5.0 Coyote engines found in 7-Gen Mustangs due to diameter - It's too big.
Ford Racing filter DOES fit. On my 3rd oil change with the CM-6731-FL820. 2025 GT.
D/\rK•650
2025 Mustang DarkHorse
I second the motorcraft FL-500-s. Not sure about any performance filters. Im not sure about KN. Motorcraft has pretty good oil and filters.
Cipis
czech republic
Mustang GT
The Motorcraft filters have taken a quality dive recently. Trying to find the video/post about it. Crappy glue inside etc.
Do you think the glue would dissolve? And if, is that concerning considering the amount of glue? Makes me a bit worried too.
Ryunker
Madison South Dakota
I use the Motorcraft filter (white one) although I choose not to use the 500a as it is huge compared to what my DH left the factory with. So I use the Motorcraft one same diameter as what it rolled home with. Just got it home from a fresh service moments ago.
