Oil consumption
@OnlyNonScout ..... engine oil consumption of that amount is not normal unless you are really beating the $hit out of it which I doubt. I assume you checked your oil level after the last fill. I recently had an oil fill that was down a quart. I pre-purchase the oil from the Ford dealer's parts department to get their FULL synthetic (and to avoid the shop bulk "whatever" oil is the flavor of the day) and then give it to the tech. I went in to see him at his bench and guess what was sitting on his bench..... yep, the 10th quart. Before I started letting them rip into the engine I'd put some miles on it after you verified the oil level in cold mode. Drips are easy to see - stem seal problems will be smoke out the pipes at that consumption rate. Good luck. BTW the tranny can be re-programmed to oem by any decent tech. The 10R80 is a good tranny and your issue should be easy to solve.
Hi @OnlyNonScout ,
What ever came of your oil loss? Was it as simple as the tech did not fill the engine correctly, or is it something more involved? Has the dealer provided any feedback yet?
89Trooper
Central Florida
Guess I'm lucky. Mine doesn't seem to have used a drop (so far--only about 3600 mi though). No A10 issues either! 🤞
highvoltage
NorCal to SoCal
2024 Mustang GT 6spd
Never taking it over 4k rpms? that’s just wrong
So0_NaSTy
NY
2024 Ford Mustang GT Premium
Ford gave me the same BS, a week just to check the trans fluid level and run diagnostics, no thanks.
A10 shudder 4th to 5th gear is known and normal, I have it. Also the adaptive learning tables could be acting up. I cleared mine in FORScan and it helped smooth out shifts and no more hunting for gears.
Have you had the trans fluid levels checked? These have been known to be a little low and cause shifting issues.
How’d you clear it in forscan?
JAM486HP
Interesting. What changed after? How often must this be done?
Much smoother shifts and no more hunting for gears in Normal Mode, a bit more responsive in Sport and Track. Only cleared it twice, been 6 months now and still feels good, though I have learned where the sweet spots are for the car now. 4K - 5K RPM is where the car wakes up, unfortunately for street 100mph+ happens real quick.
I wish it would wake up sooner, maybe after we can tune these things
So0_NaSTy
NY
Hmm. Haven’t had issues hunting, but maybe I’ll try it. And yeah coyotes are top end machines.
Doug Watson
IIRC, Ford considers 1 quarts burned ever 3000 miles acceptable, unless its a high performance engine, then its 1 quart over 500 miles
My DH burns 1 qt every 750 miles since new and I have 6100 total miles.
Eli GT
Blairsville, GA
'18-'21 Coyote engines used more oil than they should have. The issue was resolved with a PCM update in many cases, mine included for my '18 F-150, 5.0. My '25 Mustang GT was near the bottom edge of the dipstick when I got it home when brand new. I added 1/2 quart to bring it up a little more. So far it isn't using any. Don't forget to check the oil after it's been sitting a while, overnight is better. I've been told the oil is slow to drain completely into the crankcase from above in the engine.
