Normal Oil Temperature for 5.0?
silex
Indiana
It appears automatic vs manual transmissions are running significantly different temps?
JAM486HP
My Air Inlet temps are always 10 - 20 degrees higher than outside temperature, Any ideas??
S650 Mustang Normal Oil Temperature for 5.0? tem
Deleted member 61195
Guest
S650 Mustang Normal Oil Temperature for 5.0? IMG_5621
S650 Mustang Normal Oil Temperature for 5.0? IMG_5624
This was this afternoon. As you can see ambient temp 108. Humidity was around 10%. Surface street driving. Never got down to ambient temp.I think it’s probably due radiating heat from asphalt roadway. I never got on freeway to get higher airflow through radiator.
metroplex
Mr. EcoBoost
Detroit, MI
2017 Fusion Sport, 2022 Tesla Model 3 LR w/ AB
I've read that 220F-230F is the norm for engine oil temperatures, pushed as high as 260F-270F in extreme conditions. This is NOT the same as cylinder head temperature or engine coolant temperature.
BrandonS650
Indiana
2024 Ford Mustang GT Premium
I have 2024 GT Premium with kooks long tube headers, corsa double h pipe and stage 2 whipple kit and mine runs anywhere between 195-225 if I’m ripping on it and 90 degrees outside.
BrandonS650
Indiana
Cool66
Fernandina Beach, Florida
Just seeing this thread. Recently install the OEM oil cooler on my non-PP S650. Oil temps have not dropped as I would have expected them. I am going to install the PP radiator as it is 17mm thicker and should have better cooling capacity which would impact the inferred oil temps. The picture is from earlier today. Hoping to install the rear diff temp sensor and harness later next week.
S650 Mustang Normal Oil Temperature for 5.0? IMG_4049
decidave8
mobile AL
2024 mustang GT premium
What are normal oil temperatures for the 5.0?
[/QUOTE]
Oil does not even start burning off water vapor or deposits until 230 or so (needed from time to time). Synthetic oil does not start to break down until much higher. I'm not sure why everyone is worried about the oil temps on these cars, they seem to be running right where they should be.
More an issue of simulated display. If the ‘gauge’ aint accurate who’s to say it really works.
Zeeku22
Utan
S650 gt premium 10 speed
I was using forscan and passed a setting that can be changed for weather or not it has an oil cooler, you may need to have that changed.
Zeeku22
Utan
I have a s650 non pp at just over 16k, its temps hover at 235 while cruising with ambient temp of 78 on flat freeway at 75 mph. The temps have only been rising since i passed the 10k miles mark. I cant do a full canyon run anymore as temps regularly reach 280f. Ive complained to ford multiple times as it drops me into limp mode...
At 10k miles the average temp was roughly 210
Spirited it reached 230
At 13k miles it was 230
Spirited it reached 265
Now at 16k its 235
Spirited it reaches 287 (limp mode kicks at 280)
I think they need to recall them to get the oil coolers put on.
ShaBoingBoing
New York
Infiniti G37
Wish these cars came with a cooler regardless of trim. Highest so far is 257 after sprites driving. I would have to see what a non PP gt sees on a track day.
People need to stop obsessing over these temps and second guessing Ford engineers. And they also need to stop conflating oil temp and cylinder head temp. The only reason why it's even a discussion is because we now have a guage I'm front of our face 24/7. Before the S650 came out, no one ever gave it a second thought unless you had a GT350.
And the people putting oil coolers on non PP cars need to understand that oil temp is determined by a computer algorithm, not an actual dedicated sensor. So if you add a cooler, the computer won't know that or factor it into its calculations unless you do a software update.
ShaBoingBoing
New York
Infiniti G37
That’s actually pretty helpful. Thank you
