Ford has released a new safety recall affecting 4595 vehicles built between 7/25/23 to 11/15/23
"The rear suspension in some of the affected vehicles may be built with a knuckle that contains a casting imperfection. This may result in the fracturing of the knuckle. A fractured knuckle may reduce vehicle lateral stiffness and result in significant toe-in or toe-out of the rear tire under braking or throttle application. Drivers may experience limited vehicle steering control as a result, increasing the risk of a crash."
S650 Mustang NHTSA 24S49 Safety Recall - Inspect Rear Knuckle IMG_2439
kinelisch
Just checked mine and it appears that I don't have it. Yet...
9secondko
Irvine, ca
2003 cobra
Sheesh. They may as well just REPLACE them all. Of course sn inspection only catches it IF it’s already at a certain state of wear.
Crew4991
Ford has released a new safety recall affecting 4595 vehicles built between 7/25/32 to 11/15/23
LOL I realize this is just a simple typo but it is hilarious to me since Ford is the leader in recalls; I'm sure they will continue to issue recalls through 2032... :giggle:
Doug Watson
Just checked with my dealer and there saying Ford does not have a resolution yet for this recall.
RJV15
Los Angeles
2022 Honda Civic Si
My car is lowered with coilovers, does that change anything, or would I still be covered.
as long as you have the factory rear knuckles (what the wheel bearings and brake calipers mount to), you may be affected by the recall
*yawn*
my mustang passed the recall
Out of curiosity any diff for pp cars or are we using a standard ‘stocked’ part - tbh feel more comfortable letting her rest in my garage while awaiting parts than theirs, if it turns into a backorder problem.
yeah... don’t be surprised if this is extended. I got rolled into the F150 brake master cylinder recall after it was limited to a select group, then expanded over time. This one does seem to be identifiable to a specific range of parts - and likely from a particular batch/supplier.
Ford doesn’t want you dying in their cars & trucks due to a defect. Even if they may not be the quickest on the draw to recall, jury verdicts against “big, greedy” manufacturers is a popular sell in court.
Southpaw78
US
Acura MDX
For anyone that may know - Would you base the built date window for the recall on the blend date that's on your window sticker?
