Mixing E85 with 93 Octane for more power?
JoesProGTO
Illinois
youtube.com
Pro Street 74 GTO, 2024 Mustang GT Premium Coupe
I just saw the video below, where the YouTuber claims he mixes 6 gallons of E85 with 10 gallons of 93 Octane (per tankful) to gain significant horsepower in his 2024 GT….without a tune (obviously).
Any thoughts on this? He claims as long as you are keeping the overall mixture around E40 (or under E50) the ECU will not generate an error code. 🤔 I haven’t tried it yet and wanted to tap the knowledge base here first.
It's been known since the previous generation. All the shops with the fast S650's are running 30-40% E
JoesProGTO
JoesProGTO
Illinois
youtube.com
Well,my only reason for asking is I’m old-school (carburetors and high octane gas 😁) and I’m not sure if the ECU would advance timing based on the higher octane from the E. I know you lose some BTU’s from the E…just trying to fill in the gaps in my experience. I’m not a trial and error guy…I’ll trial something if I’m confident there will be no error.
Zcarmenb28
Idaho
21 Camaro ZL1, 22 Supra 3.0
Without a tune, no, I doubt it because E85 has much less energy density than gasoline, therefore, if you're at E40 you need more fuel flow per given airflow to make more power. The computer has no way of knowing its E40 without a tune so therefore it won't send more fuel, thus, less power due to the less energy dense fuel.
JoesProGTO
JoesProGTO
Illinois
youtube.com
Yes, that’s what I was thinking…the tune would allow the necessary fuel control, etc. But, according to the video shared by Q6543 above, there are some modest gains…
Zcarmenb28
Idaho
There's too many unknowns from that video. I doubt they were really at E30 or E35 like he said, unless they had very little 93 octane in the tank. To be at E30 with only 1 gal of E85 they'd have to only have 1.8 gallons of 93 octane (assuming ethanol free); I doubt they had that little, but they didn't say. Most likely what's happening is the mixture is probably more like E10 and the increase in hp is due to an increase in octane which the car can accommodate. Most cars can handle E10 from the factory, and the E85 is in small enough amounts that it is increasing the octane but still at E10 or less.
Don't go to E40 - it won't work on a factory tune.
JoesProGTO
JoesProGTO
Illinois
youtube.com
I agree with your assessment! Variables unknown. 👍 Thanks for your input.
Rocket Man
Woodbine, MD
2016 Challenger Scat Pack Shaker, 2025 GT (soon)
Noooo. Don't do it. Your fuel system components are not made for that high a concentration of ethanol. Have you read your owner's manual? Does it say to never run over 10 or 15% ethanol? Like mentioned, you are not tuned for it. Have a problem and watch them not warranty your engine due to not following recommended fuels.
JoesProGTO
JoesProGTO
Illinois
youtube.com
Yes…too many reasons not to do it. All your points are valid. Thank you and everyone else for your responses. Glad I posted. 🙂
Except as I already said, people do it. The computer will sense the car is running lean and add more fuel. The car will also give itself more timing.
IFFV68
I would never use alternate fuels?
They may Void the Factory Warranty?
I know,
Speed Costs Money.
How Fast Do You Want to Go?
