Low Battery Warning at 1,000 Miles!
DCS
Ocala, FL
This morning I got a notice on my FordPass app that remote features were disabled as my Mustang was in "Deep Sleep" mode to save the battery. I put my 5 amp Noco Genius charger on the battery. 4 hours later the charger is still on the first charging stage (indicator light).
The only possible thing I could have done yesterday was put the car in "Full Accessory" mode and forgot it. I don't remember any lights on the dash or the Start/Stop button when I left the car, but I could be mistaken. I would think the car would complain audibly if the key was removed from close proximity. I will have to test this theory out once the battery is fully charged.
The car was with the dealer to do the clutch recall (hydraulic line was secure) and do an oil & filter change on Thursday. I doubt they would have done something else and not told me.
jamespmoran
Bloomer, WI
if your vehicle is inactive for 5 days it will go into deep sleep mode. If your battery voltage drops below a certain level it will go into deep sleep mode. constant short trips will also trigger sleep mode. I also have a 22 F-150. Same scenario as the Mustang. I have a charger set up in my garage for each vehicle. If they are going to be sitting for more than 2 days they go on the charger. PIA, but it works. I learned my lesson the hard way. I had a 20 Explorer ST. It sat for 7 days while we were away. Went into deep sleep. Went 3 miles to go out to dinner. Locked the car (keys in it as I would use the keypad) keypad was deactivated and was locked out of the car.
DCS
DCS
Ocala, FL
I drive virtually every day, granted the average mileage per day is only 12 miles.
DCS
DCS
Ocala, FL
That's not enough to fully recharge so over time it could do it.
Also if you have a dash-cam and it's set to record when parked. Someone i know hod those messages and it turned out to be the dash-cam settings.
No dashcam.
Before I received the car, I had read (on this forum) about low battery conditions of new vehicles because they sit around. I put my charger on the car as soon as I got it home from the delivery. It took about 8 hours for a full charge.
Depending upon how low it was when you got it and how often/long you typically drive, it takes longer than 4 or 8 hours to bring that battery up to full charge especially with just a 5A charger.
Also, resetting the BMS after a deep charge or battery replacement is a good idea, as that's what's monitoring SOC to put the vehicle into sleep mode.
Batteries can be defective, too. Had to have the one in my '21 F150 replaced just a year in.
ihasnostang
MN
Saturn ion, 201A, EB PP1, Ruby Red ordered 4/30
i would assume like the s550, the default SoC setting for the oem battery is 80%
It changes. That's why you reset it when you replace/deep recharge. It needs to relearn (kinds like resetting the auto trans to relearn how YOU drive).
Ford Motor Company
Official Ford Account
Dearborn, MI
Ford Mustang
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
What’s the point of a bms if it don’t?
Does that imply 6 each direction? That’s barely getting warmed up but and although, as i questioned another post. What’s the point of bms if it don’t? But then again as was suggested maybe a bms relearn is due?
Edit: ā€œShort trips tend to pull more amperage than the charging system can put back into the battery, which causes certain features – such as auto stop/start – to stop working. Other times, the infotainment screen may display a message that the system has turned off to save the battery. Those that drive longer distances don’t necessarily see this happen quite as frequently, as the charging system is able to keep the battery at an optimum state of charge.ā€
https://fordauthority.com/2022/11/ford-battery-monitoring-system-explained-in-depth-by-technician/
DCS
DCS
Ocala, FL
As I explained in my first post on this issue, The problem may have been of my own making! I have driven 80 something days (since purchase) without a problem. While I was working on something in the garage in "Accessory Mode", I may have left it that way overnight. The next morning is when I got the warning.
After attaching my NOCO Genius 5 to the battery, it became fully charged in about 10 hours.
BTW: Auto start/stop is disabled as I ALWAYS run the AVE in Sport mode.
Acknowledged, but what’s the point of having a bms if it’s unable to resolve and or relay pertinent information to / for the end user.
It shuts down all unnecessary power draws (resolves), and sends notifications to fordpass app (relays information)... what more would you have it do? Hook itself to a charger?
Pre-warning/notification may be helpful. Disabling accessory if/when fob not present? Dear driver please drive me more i feel we just haven’t been spending enough quality time together…. Lol. But yes, i agree it may have preserved the battery but it seems to say it after the fact and not before as a warning…
