How to do launch control in A10?
stangjp50
montreal
19 mustang gt
I had a lunch on my lt1 camaro but i was making better in just foot braking.
John boschma
Beloit wi
2024 mustang gt
I am curious as to how I can do launch control in a A10 DH. I have 870 miles and I do not have an option for launch control in track apps. I just curious on if I am missing something.
There is no launch control. The best launchs we've managed, is starting out in second gear and foot break it to 2000rpm.
We are seeing 1.6, 60' times and have run 10.90's@126
cstraley
24 Mustang GT , 24 Tundra, 2023 M240i, 23 QX80
2 days ago I decided to try some 0-60 runs with my dragy and just hitting the gas in sport mode I got a 3.91 with a 1 ft rollout on my second run. I was getting quite a bit of tire spin. I bet if it hooked it would be closer to 3.5 to 3.6. I have minor mods. I removed the carbon from the intakes and installed a 3" catback exhaust.
put some wide tires on. i get exactly 0 wheelspin unless i launch with RPMs above 1500 or so. you should also use drag strip mode instead of sport for that kind of thing
cstraley
I plan on trying track and dragstrip mode. I doubt i'll change the tires in an attempt to improve 0-60 times. zero wheelspin huh? I hate to call bs but I gotta say......
give me a few hours to get home, i'll prove it with video
Any issues with running that wide of a tire or any adjustments that you had to make?
when the rear suspension is highly compressed, it rubs slightly on the inside of the fender, but it's really superficial
LETHAL
From the D but in the NC
From the D to NC
Roll into it from idle..Keeps torque management happy and wont bog as bad.. or spin. These cars need a tire from the get go on the track. Don't risk yourself or Mustang without a set of stickies.
AdvanceTrac off (only time i will ever do that) with the window down and there's no squeaking or chirps
cstraley
In all fairness you kind of rolled into that throttle.
