Gear indicator on A10 automatic....
Stangerous
Space Coast, Florida
ive only been able to see the gear indicator while playing with the paddles.
i do think this is one of the many things that ford will add with a furture OTA update to the car.
I hope you’re right. It’s a small issue but it drives me nuts.
young at heart
Deep South
Page 114 allows you to configure the instrument cluster but as I have a Tremec. I may not have all the options available. I also suspect if it is configurable, it's probably hidden elsewhere in the configuration structure.
Yes, hopefully so.
Like I said earlier the configuration menus on these cars seem to be a bit of a black hole. At best, they aren’t intuitive.
wilkinda65
wilkinda65
Sun City Center, FL
I already read that section and there is no option to display the gear while in D even though the instrument cluster drawing shows the selector in D while showing gear indicator being 3rd gear. It only shows up when I select M.
Hoofprint
2024 GT Convertible
Is this something that may even be configured through an OTA update??
jboogie1289
Friendswood Texas, 77546
I've wondered the same thing because on my previous S550, my custom MyMode had a Sport+ setup and the Instrument Cluster showed the current gear regardless of Drive Mode ( and it was an option in the Menu selection). I've only found that in Manual, you can only get the Indicator to show (next to the Illuminated M in the status bar plus on the display).Plus there is a large enough space for the Indicator to go just as the Speedometer has its place on the right side of the display. And when it's in "Manual", they mean Manual. On my S550, when I was decelerating slowly it would drop to a lower gear to raise RPM's or when accelerating it grabbed a Lower Gear for acceleration. Somehow, this 24 doesn't do that (and I have pretty much floored it to get the drop for a lower Gear). Maybe I didn't wait long enough but I thought that was kinda weird but also, the Gear Selector does have an "M" instead of the "S" like the S550.
Update:
Today I decided to put the Transmission in Manual and come to a Stop Light. The speed dropped considerably and when the speeds dropped to 35mph (from 50mph), it slowly and "lightly" dropped the gears down and rather quickly but without any RPM increases. Strange to me but I guess Ford feels that if you're running in "M" then we/I the driver should be downshifting.
Slothman
2024 Ecoboost Vapor Blue Nite Pony
hi, I have my 2024 displaying the current gear continuously. I had to change a line in FORScan. IPC module 720-12-01
Is it in the current spreadsheet? Maybe you could share it so others didn't have to look it up. :)
Stangerous
Were you able to use your regular subscription or did you have to request beta version?
We'll wait for that answer, but I'm betting this ("A") is the correct value to use assuming the AsBuilt is 8. If the AsBuilt is C, change to an E.
S650 Mustang Gear indicator on A10 automatic.... 1715797955837-ex
Slothman
We'll wait for that answer, but I'm betting this ("A") is the correct value to use:
Yeah it’s that one. Change the digit to A. There’s also an option in forscan to view all the editable options as a list.
Current gear is always displayed in all driving modes.
Stang24
Chicago
2024 mustang
I don’t have a windows for forscan someone try this to confirm it lol I’ll have to buy a windows to do that if it works with no errors
Clearly, @Slothman has confirmed it is working. See the posts immediately above yours.
Which version of FORScan are you using? 2.3.59 or 2.3.60, I presume?
Slothman
I was using 2.3.60. Now I’m using the latest beta. just a note, the gear isn’t displayed in park, neutral and reverse. Only drive and manual.
I am interested in enabling active exhaust but so far I’ve had no luck.
